UPDATE: Partially solved in 6.8.0 rc6. No loss of network connectivtiy anymore. But parity checks are now painfully slow (see parity speed thread for 6.8RC)
UPDATE: The problem still persists with 6.7.3 RC4, although recovery speed seems faster then with 6.7.3. RC1 and parity check speed improved by 10% (on my slow J1900 with eight 8TB drives and dual parity)
UPDATE: The problem still persists with 6.7.3 RC1
I first noticed this with 6.7.0 RC6 and verified on RC7 and RC8, but it might be present in all 6.7.0 RCs. If I start a parity check [7 8TB drives and 2 Parity 8Tb drives) it maxes out one CPU core fully (parity calculation takes its toll on the J1900) - this has been normal for quite some versions and is not the main problem, even though it might be possible to optimize parity calculation (making it multithreaded, or getting rid of some redudant operations). The problem is that as of 6.7.0 RC6 (can't confirm or deny for earlier RCs) this leads to not servicing some IRQs on the network hardware. The parity check continues, but naturally the webinterface becomes very unresponsive because it takes some time for the network connection to reestablish itself. It might be new linux kernel as there has been some changes in this regard (maybe in conjunction with my specific hardware). With 6.6.x no such problems existed. The log show this:
Apr 10 08:54:53 Tower emhttpd: req (4): startState=STARTED&file=&cmdCheck=Check&csrf_token=****************
Apr 10 08:54:53 Tower kernel: mdcmd (89): check nocorrect
Apr 10 08:54:53 Tower kernel: md: recovery thread: check P Q ...
Apr 10 08:54:53 Tower kernel: md: using 3072k window, over a total of 7814026532 blocks.
Apr 10 08:57:08 Tower kernel: ------------[ cut here ]------------
Apr 10 08:57:08 Tower kernel: NETDEV WATCHDOG: eth0 (tg3): transmit queue 0 timed out
Apr 10 08:57:08 Tower kernel: WARNING: CPU: 3 PID: 0 at net/sched/sch_generic.c:461 dev_watchdog+0x15f/0x1b7
Apr 10 08:57:08 Tower kernel: Modules linked in: ipt_MASQUERADE iptable_nat nf_nat_ipv4 iptable_filter ip_tables nf_nat it87 hwmon_vid xfs nfsd lockd grace sunrpc md_mod tg3 intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel cryptd intel_cstate i2c_i801 i2c_core ahci libahci iosf_mbi video thermal backlight fan button pcc_cpufreq [last unloaded: tg3]
Apr 10 08:57:08 Tower kernel: CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.19.33-Unraid #1
Apr 10 08:57:08 Tower kernel: Hardware name: Insyde AS Series/Type2 - Board Product Name, BIOS V1.37 01/27/2015
Apr 10 08:57:08 Tower kernel: RIP: 0010:dev_watchdog+0x15f/0x1b7
Apr 10 08:57:08 Tower kernel: Code: b1 59 97 00 00 75 36 4c 89 ef c6 05 a5 59 97 00 01 e8 4b b9 fd ff 89 e9 4c 89 ee 48 c7 c7 6e 66 d9 81 48 89 c2 e8 2f 1e b2 ff <0f> 0b eb 0f ff c5 48 81 c2 40 01 00 00 39 cd 75 98 eb 13 48 8b 83
Apr 10 08:57:08 Tower kernel: RSP: 0018:ffff888277b83ea0 EFLAGS: 00010286
Apr 10 08:57:08 Tower kernel: RAX: 0000000000000000 RBX: ffff888272142438 RCX: 0000000000000007
Apr 10 08:57:08 Tower kernel: RDX: 0000000000000006 RSI: ffff888277b964e0 RDI: ffff888277b964e0
Apr 10 08:57:08 Tower kernel: RBP: 0000000000000000 R08: 0000000000000003 R09: 0000000000020300
Apr 10 08:57:08 Tower kernel: R10: 0000000000000472 R11: 0000000000017ee0 R12: ffff88827214241c
Apr 10 08:57:08 Tower kernel: R13: ffff888272142000 R14: ffff888272105580 R15: 0000000000000003
Apr 10 08:57:08 Tower kernel: FS: 0000000000000000(0000) GS:ffff888277b80000(0000) knlGS:0000000000000000
Apr 10 08:57:08 Tower kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 10 08:57:08 Tower kernel: CR2: 000014cd9c640000 CR3: 000000027219a000 CR4: 00000000001006e0
Apr 10 08:57:08 Tower kernel: Call Trace:
Apr 10 08:57:08 Tower kernel: <IRQ>
Apr 10 08:57:08 Tower kernel: call_timer_fn+0x18/0x7b
Apr 10 08:57:08 Tower kernel: ? qdisc_reset+0xc0/0xc0
Apr 10 08:57:08 Tower kernel: expire_timers+0x7f/0x8e
Apr 10 08:57:08 Tower kernel: run_timer_softirq+0x72/0x120
Apr 10 08:57:08 Tower kernel: ? enqueue_hrtimer.isra.3+0x23/0x27
Apr 10 08:57:08 Tower kernel: ? __hrtimer_run_queues+0xd7/0x105
Apr 10 08:57:08 Tower kernel: ? recalibrate_cpu_khz+0x1/0x1
Apr 10 08:57:08 Tower kernel: ? ktime_get+0x3a/0x8d
Apr 10 08:57:08 Tower kernel: __do_softirq+0xce/0x1e2
Apr 10 08:57:08 Tower kernel: irq_exit+0x5e/0x9d
Apr 10 08:57:08 Tower kernel: smp_apic_timer_interrupt+0x7e/0x91
Apr 10 08:57:08 Tower kernel: apic_timer_interrupt+0xf/0x20
Apr 10 08:57:08 Tower kernel: </IRQ>
Apr 10 08:57:08 Tower kernel: RIP: 0010:cpuidle_enter_state+0xe8/0x141
Apr 10 08:57:08 Tower kernel: Code: ff 45 84 ff 74 1d 9c 58 0f 1f 44 00 00 0f ba e0 09 73 09 0f 0b fa 66 0f 1f 44 00 00 31 ff e8 03 47 be ff fb 66 0f 1f 44 00 00 <48> 2b 1c 24 b8 ff ff ff 7f 48 b9 ff ff ff ff f3 01 00 00 48 39 cb
Apr 10 08:57:08 Tower kernel: RSP: 0018:ffffc90000cefea0 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff13
Apr 10 08:57:08 Tower kernel: RAX: ffff888277ba0b00 RBX: 00002d13e912c1b9 RCX: 000000000000001f
Apr 10 08:57:08 Tower kernel: RDX: 00002d13e912c1b9 RSI: 0000000040068e64 RDI: 0000000000000000
Apr 10 08:57:08 Tower kernel: RBP: ffff888277ba8d10 R08: 0000000000000002 R09: 00000000000203c0
Apr 10 08:57:08 Tower kernel: R10: 00000000000441fc R11: 00005a6aed31e218 R12: 0000000000000001
Apr 10 08:57:08 Tower kernel: R13: 0000000000000001 R14: ffffffff81e59e78 R15: 0000000000000000
Apr 10 08:57:08 Tower kernel: do_idle+0x192/0x20e
Apr 10 08:57:08 Tower kernel: cpu_startup_entry+0x6a/0x6c
Apr 10 08:57:08 Tower kernel: start_secondary+0x197/0x1b2
Apr 10 08:57:08 Tower kernel: secondary_startup_64+0xa4/0xb0
Apr 10 08:57:08 Tower kernel: ---[ end trace 3dab24a7f901a6f0 ]---
Apr 10 08:57:08 Tower kernel: tg3 0000:03:00.0 eth0: transmit timed out, resetting
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000000: 0x16b114e4, 0x00100406, 0x02000010, 0x00000010
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000010: 0x9071000c, 0x00000000, 0x9070000c, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000020: 0x00000000, 0x00000000, 0x00000000, 0x96b114e4
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000030: 0xfffff800, 0x00000048, 0x00000000, 0x0000010a
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000040: 0x00000000, 0x00000001, 0xc8035801, 0x16002008
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000050: 0x00000003, 0x00000000, 0x0086a005, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000060: 0x00000000, 0x00000000, 0xf1000298, 0x01f80051
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000070: 0x000010b2, 0xfd10b201, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000080: 0x16b114e4, 0x800000f8, 0x00000000, 0x00000120
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000090: 0x00000000, 0x000001b8, 0x00000000, 0x000001ac
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000000a0: 0x8004ac11, 0x00000002, 0x00000122, 0x00020010
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000000b0: 0x00688d80, 0x00102400, 0x00075c11, 0x10110040
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000000d0: 0x0000001f, 0x00000000, 0x00000000, 0x00000001
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000000f0: 0x00000000, 0x00000000, 0x00000000, 0x57785100
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000100: 0x13c10001, 0x00000000, 0x00000000, 0x00062030
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000110: 0x00000000, 0x00002000, 0x000000a0, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000130: 0x00000000, 0x00000000, 0x00000000, 0x15010003
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000140: 0x488ac130, 0x000010bf, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000150: 0x16010004, 0x00000000, 0x00078116, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000160: 0x00010002, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000170: 0x00000000, 0x800000ff, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000200: 0x00000000, 0x00000001, 0x00000000, 0x00000001
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000210: 0x00000000, 0xa9000000, 0x00000000, 0xc4000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000220: 0x00000000, 0x00000001, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000260: 0x00000000, 0x00000000, 0x00000000, 0x000001ac
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000280: 0x00000000, 0x00000120, 0x00000000, 0x00000333
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000290: 0x00000000, 0x000001a3, 0x00000000, 0x000002e2
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000300: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000310: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000320: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000330: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000340: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000350: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000360: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000370: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000380: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000390: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000003a0: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000003b0: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000003c0: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000003d0: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000003e0: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000003f0: 0x00000000, 0x000001b8, 0x00000000, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000400: 0x00e04808, 0x00400000, 0x00001000, 0x00000880
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000410: 0x000010bf, 0x488ac130, 0x000010bf, 0x488ac130
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000420: 0x000010bf, 0x488ac130, 0x000010bf, 0x488ac130
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000430: 0x00000000, 0x00000000, 0x0000031d, 0x000005f2
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000440: 0x00000000, 0x00000000, 0x00000000, 0x04384400
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000450: 0x00000001, 0x00008000, 0x00000000, 0x00000112
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000460: 0x0000000e, 0x00002620, 0x01ff0006, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000470: 0xa0002000, 0x00000080, 0x00000000, 0x50000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000480: 0x42000000, 0x7fffffff, 0x06000004, 0x7fffffff
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000500: 0x00000008, 0x00000001, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000590: 0x00900110, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000005c0: 0xd320fa58, 0x018b84de, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000600: 0xffffffff, 0x00f80011, 0x00000000, 0x00001f04
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000610: 0xffffffff, 0x00000000, 0x07c00004, 0x30000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000620: 0x00000040, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000630: 0x01230123, 0x01230123, 0x01230123, 0x01230123
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000640: 0x01230123, 0x01230123, 0x01230123, 0x01230123
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000650: 0x01230123, 0x01230123, 0x01230123, 0x01230123
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000660: 0x01230123, 0x01230123, 0x01230123, 0x01230123
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000670: 0xfab2595a, 0x19671df2, 0xb131d7e7, 0x381e557c
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000680: 0x08d67ba0, 0xb9fa539d, 0x5fa0f59b, 0x1562f543
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000690: 0x97135ee8, 0xfa1ad7df, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000800: 0x00000000, 0xffffffff, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000810: 0x00000000, 0xffffffff, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000820: 0x00000000, 0x00000000, 0xffffffff, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000830: 0x00000000, 0xffffffff, 0xffffffff, 0xffffffff
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000840: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000850: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000860: 0xffffffff, 0xffffffff, 0xffffffff, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000880: 0x00000165, 0x001ddd00, 0x00000000, 0x00000003
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000008f0: 0x007c0001, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000c00: 0x0000000a, 0x00000000, 0x00000003, 0x00000001
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000c10: 0x00000000, 0x00000000, 0x00000000, 0x1d880000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000c80: 0x001eb379, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000ce0: 0x7a8853ac, 0x00000001, 0x006604ec, 0x000c062c
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00000cf0: 0x00000000, 0x40000038, 0x84ec0066, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001000: 0x00000002, 0x00000000, 0xa000545f, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001010: 0x01b81b80, 0x0001545f, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001400: 0x00000006, 0x00000000, 0x00000000, 0x00000005
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001440: 0x000001b8, 0x000001b8, 0x000001b8, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001450: 0x000001b8, 0x000001b8, 0x000001b8, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001460: 0x000001b8, 0x000001b8, 0x000001b8, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001470: 0x000001b8, 0x000001b8, 0x000001b8, 0x000001b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001800: 0x00000016, 0x00000000, 0x000001b8, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001840: 0x00000000, 0x00000000, 0x00000200, 0x00000010
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001850: 0x0000001f, 0x00000002, 0x00004360, 0x01b801b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001860: 0x02000000, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00001c00: 0x00000002, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002000: 0x00000002, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002010: 0x00000181, 0x00000001, 0x007bffff, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002100: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002110: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002120: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002130: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002140: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002150: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002160: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002170: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002180: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002190: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000021a0: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000021b0: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000021c0: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000021d0: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000021e0: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000021f0: 0x000cc262, 0x000cc262, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002200: 0x00f93a8a, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002400: 0x00000012, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002440: 0x00000000, 0x00000000, 0x00000002, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002450: 0x00000002, 0x507c4000, 0x02001800, 0x00006000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002470: 0x00000000, 0x00000134, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000024c0: 0x00800101, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002800: 0x00000006, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002c00: 0x00000006, 0x00000000, 0x00000000, 0x000001a0
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002c10: 0x00000000, 0x00000000, 0x00000020, 0x0000000c
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00002c20: 0x00020002, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003000: 0x00000006, 0x00000000, 0x00000000, 0x000001a0
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003600: 0x00037c00, 0x00130000, 0x00110000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003610: 0x00170000, 0x00130000, 0x00150000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003620: 0x00000000, 0x00000000, 0x00000000, 0x00032080
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003630: 0x00000000, 0x80008000, 0x00001080, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003640: 0x0000000a, 0x02f00003, 0x00000020, 0x0000004b
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003650: 0x00000171, 0x00000bff, 0x57785100, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003660: 0x00000000, 0x00000000, 0x000400a7, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003670: 0x0000002a, 0xfefffff7, 0x0000000a, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000036a0: 0x00000000, 0x00000000, 0x00000000, 0x00000040
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000036b0: 0x001003c8, 0x07ff07ff, 0x07ff07ff, 0x01000004
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000036c0: 0xffffffff, 0x2338530a, 0x00000002, 0x48c42fe6
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000036d0: 0x0000019d, 0x00000000, 0x00000000, 0x00001274
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000036e0: 0x00000b19, 0x10880819, 0x00580819, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003c00: 0x00000302, 0x00000000, 0x00000000, 0x00000048
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003c10: 0x00000000, 0x00000035, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003c20: 0x00000000, 0x00000005, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003c30: 0x00000000, 0x00000000, 0x00000002, 0x72d55000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003c40: 0x00000000, 0x00000b00, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003c50: 0x00000000, 0x0000013a, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003c80: 0x0000015b, 0x00000333, 0x000001a4, 0x00000308
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003cc0: 0x000001b8, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003cd0: 0x00000000, 0x0000000f, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003d00: 0x00000002, 0x71d15000, 0x00000002, 0x7210f000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003d10: 0x00000002, 0x7210e000, 0x00000002, 0x7186f000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003d80: 0x00000014, 0x00000000, 0x00000005, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003d90: 0x00000005, 0x00000000, 0x00000014, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003da0: 0x00000005, 0x00000000, 0x00000005, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003db0: 0x00000014, 0x00000000, 0x00000005, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003dc0: 0x00000005, 0x00000000, 0x00000014, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00003dd0: 0x00000005, 0x00000000, 0x00000005, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004000: 0x00000002, 0x00000000, 0x000acd10, 0x000e2601
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004010: 0x0045f060, 0x0026d012, 0x00800440, 0x00848082
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004020: 0x00000000, 0x00000010, 0x00000010, 0x00000050
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004030: 0x00000000, 0x01086e20, 0x0026d010, 0x00455002
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004040: 0x00460000, 0x0f345e00, 0x00000010, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004400: 0x00000006, 0x00000000, 0x00010000, 0x0000a000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004410: 0x00000000, 0x0000002a, 0x000000a0, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004420: 0x0000003d, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004440: 0x00000000, 0x00000000, 0x00000000, 0x05417c61
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004450: 0x0002033f, 0x006e006f, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004800: 0x180303fe, 0x00000000, 0x00000000, 0x00000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004810: 0x00000000, 0x00000004, 0x02000acd, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004820: 0x00000060, 0x00000000, 0xf02c0000, 0x507c7400
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004830: 0x00000000, 0x0000010c, 0x0000010c, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004840: 0x00000081, 0x01798b81, 0x000e2200, 0x6036d8aa
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004850: 0xae726877, 0xe59a0522, 0x55545554, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004860: 0x01000060, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004900: 0x00028207, 0x50205408, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004910: 0x00000018, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004c00: 0x200003fe, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004c10: 0x0000002a, 0x00000000, 0x00000006, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004c20: 0x00000000, 0x00000000, 0x00000000, 0x00000006
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004c30: 0x00000000, 0x00570000, 0x00000093, 0x00000093
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004c40: 0x00000000, 0x71d15000, 0x00010020, 0x00040020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004c50: 0x1a3cc95b, 0x13bfff07, 0x30869333, 0x003bb8b8
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00004c60: 0x00000020, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005000: 0x00009800, 0x80008000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005010: 0x00000000, 0x00000000, 0x00000000, 0x40003c84
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005020: 0x24a50001, 0x00000000, 0x00000000, 0x40000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005030: 0x00000000, 0x00000051, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005040: 0x00000000, 0x00000000, 0x40003274, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005080: 0x00009800, 0x80000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005090: 0x00000000, 0x00000000, 0x00000000, 0x40003b30
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000050a0: 0x8f87105c, 0x00000000, 0x00000000, 0x40000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000050b0: 0x00000000, 0x00000051, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000050c0: 0x00000000, 0x00000000, 0x40003c7c, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005100: 0x00009800, 0x80000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005110: 0x00000000, 0x00000000, 0x00000000, 0x400033ec
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005120: 0x3c04dead, 0x00000000, 0x00000000, 0x40000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005130: 0x00000000, 0x00000051, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005140: 0x00000000, 0x00000000, 0x400033ec, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005180: 0x00009800, 0x80008000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005190: 0x00000000, 0x00000000, 0x00000000, 0x40003c70
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000051a0: 0x00051840, 0x00000000, 0x00000000, 0x40000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000051b0: 0x00000000, 0x00000051, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000051c0: 0x00000000, 0x00000000, 0x400033f4, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005200: 0x00000000, 0x00000000, 0x0800ffc0, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005210: 0x00000001, 0x00000000, 0x00009810, 0x0800ffc0
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005220: 0x0800ffe0, 0x40001fa4, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005230: 0x00000001, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005250: 0x00000000, 0x00009810, 0x00080000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005260: 0xb49a89ab, 0x00000000, 0x0800ffc0, 0x0800ffc0
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005270: 0x00000001, 0x00000000, 0x00009810, 0x0800ffc0
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005280: 0x00009800, 0x80000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005290: 0x00000000, 0x00000000, 0x00000000, 0x40003b0c
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000052a0: 0x00a09021, 0x00000000, 0x00000000, 0x40000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000052b0: 0x00000000, 0x00000051, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000052c0: 0x00000000, 0x00000000, 0x40003c7c, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005300: 0x00009800, 0x80000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005310: 0x00000000, 0x00000000, 0x00000000, 0x40003b38
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005320: 0x3c02dead, 0x00000000, 0x00000000, 0x40000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005330: 0x00000000, 0x00000051, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005340: 0x00000000, 0x00000000, 0x40003c62, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005380: 0x00009800, 0x80008000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005390: 0x00000000, 0x00000000, 0x00000000, 0x400033f4
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000053a0: 0x1460fff4, 0x00000000, 0x00000000, 0x40000020
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000053b0: 0x00000000, 0x00000051, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000053c0: 0x00000000, 0x00000000, 0x40003274, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005800: 0x00000000, 0xb8000000, 0x00000000, 0x82000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005810: 0x00000000, 0xa9000000, 0x00000000, 0x00000001
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005820: 0x00000000, 0xde000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005860: 0x00000000, 0x00000000, 0x00000000, 0x0000003c
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005880: 0x00000000, 0x0000015e, 0x00000000, 0x00000333
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005890: 0x00000000, 0x000001a3, 0x00000000, 0x00000308
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005900: 0x00000000, 0x000001b8, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005980: 0x000001b8, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00005a00: 0x000f601f, 0x00000000, 0x00010000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006000: 0x00000082, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006400: 0x00000000, 0x00000000, 0x00010191, 0xc0000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006410: 0x50000016, 0x50000016, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006430: 0x00000000, 0x14e416b1, 0x96b114e4, 0x10020000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006440: 0x0000304b, 0x000002e4, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000064c0: 0x00000004, 0x00000002, 0x00000122, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000064d0: 0x00000000, 0x00008d80, 0x00000000, 0x00d75e11
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000064e0: 0x00000031, 0x0000001f, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000064f0: 0x00000002, 0x00000030, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006500: 0x01e10003, 0x488ac130, 0x000010bf, 0x00000003
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006510: 0x00078116, 0x0005810b, 0x00046105, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006550: 0x00000000, 0x02800000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006800: 0x04130034, 0x20081082, 0x01000018, 0xc8a9f986
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006810: 0xa1000000, 0xffffffff, 0x00000000, 0x000000f0
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006880: 0x77fff020, 0x00000040, 0x081316b1, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006890: 0x00800000, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000068a0: 0x00000000, 0x00010001, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x000068b0: 0x00040000, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00006900: 0x2134a508, 0x00000000, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00007000: 0x20000108, 0x00000000, 0x00000014, 0x00000074
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00007010: 0x03780c10, 0x02008200, 0x000500db, 0xa100a000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00007020: 0x00000000, 0x00000000, 0x00000406, 0x10004000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00007030: 0x00020000, 0x00000078, 0x001f0000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00007500: 0x00000000, 0x00000000, 0x0000008f, 0x00000082
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0x00007510: 0x00000000, 0x00001024, 0x00000000, 0x00000000
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0: Host status block [00000001:000000b8:(0000:00df:0000):(0000:01b8)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 0: NAPI info [000000b8:000000b8:(01b8:01b8:0100):0000:(004d:0000:0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 1: Host status block [00000001:00000092:(0000:0000:0000):(016e:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 1: NAPI info [00000092:00000092:(0000:0000:0100):016e:(016e:016e:0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 2: Host status block [00000001:000000a9:(0333:0000:0000):(0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 2: NAPI info [000000a9:000000a9:(0000:0000:0100):0333:(0133:0133:0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 3: Host status block [00000001:000000c5:(0000:0000:0000):(0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 3: NAPI info [000000c4:000000c4:(0000:0000:0100):01a3:(01a3:01a3:0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 4: Host status block [00000001:000000df:(0000:0000:0309):(0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: 4: NAPI info [000000df:000000df:(0000:0000:0100):0309:(0109:0109:0000:0000)]
Apr 10 08:57:11 Tower kernel: tg3 0000:03:00.0 eth0: Link is down
Apr 10 08:57:11 Tower dhcpcd[1645]: eth0: carrier lost
Apr 10 08:57:11 Tower avahi-daemon[5570]: Withdrawing address record for 192.168.178.29 on eth0.
Apr 10 08:57:11 Tower avahi-daemon[5570]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.178.29.
Apr 10 08:57:11 Tower avahi-daemon[5570]: Interface eth0.IPv4 no longer relevant for mDNS.
Apr 10 08:57:12 Tower ntpd[1706]: Deleting interface #1 eth0, 192.168.178.29#123, interface stats: received=128, sent=130, dropped=0, active_time=49495 secs
Apr 10 08:57:12 Tower ntpd[1706]: 195.201.19.162 local addr 192.168.178.29 -> <null>
Apr 10 08:57:12 Tower ntpd[1706]: Deleting interface #3 eth0, fe80::12bf:48ff:fe8a:c130%12#123, interface stats: received=0, sent=0, dropped=0, active_time=49495 secs
Apr 10 08:57:14 Tower kernel: tg3 0000:03:00.0 eth0: Link is up at 1000 Mbps, full duplex
Apr 10 08:57:14 Tower kernel: tg3 0000:03:00.0 eth0: Flow control is on for TX and on for RX
Apr 10 08:57:14 Tower kernel: tg3 0000:03:00.0 eth0: EEE is enabled
Apr 10 08:57:15 Tower dhcpcd[1645]: eth0: deleting route to 192.168.178.0/24
Apr 10 08:57:15 Tower dhcpcd[1645]: eth0: deleting default route via 192.168.178.1
Apr 10 08:57:15 Tower dhcpcd[1645]: eth0: carrier acquired
Apr 10 08:57:15 Tower ntpd[1706]: Listen normally on 4 eth0 [fe80::12bf:48ff:fe8a:c130%12]:123
Apr 10 08:57:15 Tower ntpd[1706]: new interface(s) found: waking up resolver
Apr 10 08:57:16 Tower dhcpcd[1645]: eth0: rebinding lease of 192.168.178.29
Apr 10 08:57:16 Tower dhcpcd[1645]: eth0: probing address 192.168.178.29/24
Apr 10 08:57:20 Tower dhcpcd[1645]: eth0: leased 192.168.178.29 for 864000 seconds
Apr 10 08:57:20 Tower dhcpcd[1645]: eth0: adding route to 192.168.178.0/24
Apr 10 08:57:20 Tower dhcpcd[1645]: eth0: adding default route via 192.168.178.1
Apr 10 08:57:20 Tower avahi-daemon[5570]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.29.
Apr 10 08:57:20 Tower avahi-daemon[5570]: New relevant interface eth0.IPv4 for mDNS.
Apr 10 08:57:20 Tower avahi-daemon[5570]: Registering new address record for 192.168.178.29 on eth0.IPv4.
Apr 10 08:57:21 Tower ntpd[1706]: Listen normally on 5 eth0 192.168.178.29:123
Apr 10 08:57:21 Tower ntpd[1706]: new interface(s) found: waking up resolver
Apr 10 08:59:08 Tower emhttpd: req (5): startState=STARTED&file=&csrf_token=****************&cmdNoCheck=Cancel
Apr 10 08:59:08 Tower kernel: mdcmd (90): nocheck Cancel
Apr 10 08:59:08 Tower kernel: md: recovery thread: exit status: -4
Recommended Comments
