- Closed
I created a second cache pool for my nvme drive. The mounting point is /mnt/nvme .
Disk log:
Jul 31 13:14:02 UnraidServer emhttpd: PNY_CS3030_1TB_SSD_PNY10200004940301CEB (nvme0n1) 512 1953525168 Jul 31 13:14:02 UnraidServer emhttpd: import 32 cache device: (nvme0n1) PNY_CS3030_1TB_SSD_PNY10200004940301CEB Jul 31 13:14:44 UnraidServer emhttpd: writing MBR on disk (nvme0n1) with partition 1 offset 2048, erased: 0 Jul 31 13:14:44 UnraidServer emhttpd: re-reading (nvme0n1) partition table Jul 31 13:14:45 UnraidServer kernel: nvme0n1: p1 Jul 31 13:14:45 UnraidServer emhttpd: shcmd (1224): /sbin/wipefs -a /dev/nvme0n1p1 Jul 31 13:14:45 UnraidServer root: /dev/nvme0n1p1: 4 bytes were erased at offset 0x00000000 (xfs): 58 46 53 42 Jul 31 13:14:45 UnraidServer emhttpd: shcmd (1225): mkfs.xfs -m crc=1,finobt=1 -f /dev/nvme0n1p1 Jul 31 13:14:45 UnraidServer root: meta-data=/dev/nvme0n1p1 isize=512 agcount=4, agsize=61047598 blks Jul 31 13:14:46 UnraidServer emhttpd: shcmd (1227): mount -t xfs -o noatime /dev/nvme0n1p1 /mnt/nvme Jul 31 13:14:46 UnraidServer kernel: XFS (nvme0n1p1): Mounting V5 Filesystem Jul 31 13:14:46 UnraidServer kernel: XFS (nvme0n1p1): Ending clean mount
I changed the cache pool for the user share 'system' to nvme.
In the docker settings the value of 'Docker vDisk location' is '/mnt/user/system/docker/docker.img'.
I installed a new docker container.
If i now browse /mnt/nvme there is no file. The system directory is on /mnt/cache.
I disabled docker and started the mover, but nothing happens.
The docker vDisk is on: /mnt/cache/system/docker/docker.img
Docker settings: /mnt/user/system/docker/docker.img
User share 'system' cache pool: nvme
nvme mount point: /mnt/nvme
The docker container run without any problems.
Do i anything wrong or is this a bug?
