[7.0 RC1] Encrypted ZFS array won't start
  • Urgent
Hi team,
I recently upgraded to the 7.0 rc1 (from beta4) and encountered my first issue with unraid. The (zfs+luks) array won't mount. If I manually go through `cryptsetup open` each of the array members, they successfully mount. If afterwards, I try `zfs import` then it complains about the cache drive being missing (and to use `zpool replace` on it). It seems like the drives are all there, but the startup scripts get hung on something that I can't see.
I tried to search for logs files or even a mention of `cryptsetup` anywhere in the array without success. I could do it all manually, but I'm not sure if that will play nice with unraid's GUI or if the GUI will be confused about me changing state out from under it. I did try reverting back to beta4 without success. It has the same issue.
Thoughts?
https://limetechnology.freshdesk.com/support/tickets/4812
