Array Speed Issues Unraid 7RC1
  • Closed
I updated to 7RC1 and everything appeared fine initially, Yesterday the system locked up completely copying a few files, during the parity calculation it spiked my CPU to 95% until the system became unresponsive. Upon powering the system down hard and restarting, the system wanted to run a parity check obviously. I noticed it was hovering around 10MB/s on each of the 12 drives instead of the 125MB/s. Then I started picking up a couple CRC errors. Looking at the log at the time i was seeing ALOT of resets on my HBA.
I have a 9300-16i which is just 2 SAS3008, that was reported on FW 7.xx so I pulled the card and flashed version 16.xx from a truenas forum I found describing similar issues. Upon restarting the HBA reset errors have gone away but im still seeing about 15MB/s on each drive and occasionally spike to 65-75MB/s. Parity says its going to take 5-6Days to complete.
I had no issues under unraid 6.12.11 with this and it actually just completed parity back on the 1st in 13 hours. For now im going to let parity run and keep an eye on it. Ill attach diagnostics and anything else needed.
gaia-diagnostics-20241206-1333.zip
