Intel G5420 CPU frequent stuck at 100% even low load 6.10.0-rc4
  • Solved
  • Minor
Update:
From tip and tweaks plug post, Intel newer CPU run with P-state driver, it is sensitive. The workaround to disable Intel p-state driver works.
The CPU runs at low frequent 800Mhz.
 I suspect dir cache plug spike CPU, so CPU are not able to run at base frequent.  then I disabled dir cache plug, but the problem is persisted.
I compare electricity consumed when enable or disable Intel P state driver, they are almost the same.  This is unbelievable if CPU keep running at high frequency.
then I use  cpufreq-info cli to check, finds current CPU frequency is expected at 800MHz.  watch command seem incorrect.
But one more issue, if I uninstall tip and tweaks plug, then CPU governor set to performance. I do not know what is default value, but I think for most users, we want to save power at this moment.
###  cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to [email protected], please.
analyzing CPU 0:
  driver: intel_pstate
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency: 4294.55 ms.
  hardware limits: 800 MHz - 3.80 GHz
  available cpufreq governors: performance, powersave
  current policy: frequency should be within 800 MHz and 3.80 GHz.
                  The governor "powersave" may decide which speed to use
                  within this range.
  current CPU frequency is 800 MHz.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Every 2.0s: grep "cpu MHz" /proc/cpuinfo                          Wed Apr  6 21:44:22 2022
cpu MHz         : 800.134
cpu MHz         : 3800.000
cpu MHz         : 3800.000
cpu MHz         : 3800.000
Media server
Unraid OS Trial
Version 6.10.0-rc4
CPU: Intel G5420
New to unraid, I found my machine consume two times power than ubuntu, even all disks already spin down.
After check, I found the frequent of most CPU cores high to 3800, but all 800 for my CPU at low load. All VMs and container stopped.
Every 2.0s: grep "cpu MHz" /proc/cpuinfo                            Bovin-lab: Mon Apr  4 10:09:09 2022
cpu MHz         : 3800.000
cpu MHz         : 800.102
cpu MHz         : 3800.000
cpu MHz         : 3800.000
Top
Tasks: 229 total,   1 running, 228 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.1 us,  1.3 sy,  0.0 ni, 97.4 id,  0.2 wa,  0.0 hi,  0.0 si,  0.0 st
top - 10:10:06 up 43 min,  0 users,  load average: 0.08, 0.11, 0.34
Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.0 us,  1.1 sy,  0.0 ni, 97.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :  15568.4 total,  14179.1 free,    340.6 used,   1048.8 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.  14259.2 avail Mem
I installed fix common problem, no issue reported.
I installed tips and tweaks, CPU already set to power save mode. I tried performance or schedule, no different.  also tried to reboot it.
