I am running RC8.
So I noticed these issues mostly after I moved my server from my house to my parents house. Same type of router at both places and I am using the same Ethernet jack on the server. I tried posting in the general support and OpenVPN threads but got no responses.
When I try to create a docker container in bridged mode, I get an error. Like OpenVPN, it creates the following error in Unraid when creating the docker.
root@localhost:# /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker run -d --name='openvpn-as' --net='bridge' --privileged=true -e TZ="America/New_York" -e HOST_OS="Unraid" -e 'PGID'='100' -e 'PUID'='99' -p '943:943/tcp' -p '9443:9443/tcp' -p '1194:1194/udp' -v '/mnt/user/appdata/openvpn-as':'/config':'rw' --cap-add=NET_ADMIN 'linuxserver/openvpn-as'
2db644cbe114cf98f572146527017eaf2b36c5c07b8e2067397a40fec014b4f0
/usr/bin/docker: Error response from daemon: driver failed programming external connectivity on endpoint openvpn-as (796acda4fb1e3107e89ff13f829123f4c4b4628eea5a94ce14f9bd96102e9789): (iptables failed: iptables --wait -t filter -A DOCKER ! -i docker0 -o docker0 -p tcp -d 172.17.0.4 --dport 9443 -j ACCEPT: iptables: No chain/target/match by that name.
(exit status 1)).
The command failed.
https://imgur.com/NaMcd85 and https://imgur.com/IZGFpXY This is the docker creation page for OpenVPN I am talking about.
Here are my network settings.
https://imgur.com/mspL162 https://imgur.com/ftysL1E https://imgur.com/2AloCA9
