[6.12.1] Slow network speed with Realtek RTL8125 network card and UNRAID
  • Minor
I have built an new UNRAID ITX-System and want to use the onboard Realtek RTl8125BG network adapter because of the support of 2,5GBit/s network speed. The network adapter is recognised correctly and is using the kernel integrated r8169 driver. I have expirienced the already known problem like in the thread below:
With iperf3 I am also reaching nearly the whole performance of the max. 2,5GBit/s in both directions. But If I use an SMB share and try to load an big file on it, I only reach approx. 30MByte/s upload speed. Download instead ist working fine. The file was loaded to an Samsung 970 Evo Plus M.2 SSD so this should not be the bootleneck here. It seems that the r8169 driver is not working well with the RTL8125BG network card in my case. The only "and not good" solution was to load an different bzmodules and bzimage file from these chinese unraid forum thread:
After blacklisting the r8169 kernel driver the new r8125 driver was loaded and the adapter was working well afterwards with up- and downlink speeds of nearly 300MByte/s when using SMB shares. Is there any solution how to get this fixed without exchanging the whole bzmodules/bzimage file and load only the extra driver for my network card?
best regards René
unraid-diagnostics-20230506-1403.zip
