[6.6.1] docker stats command for cpu load and memory load running almost constantly
  • Annoyance
The following command within 6.6.0 (and now confirmed in 6.6.1) seems to be constantly running:
docker stats --no-stream --format={{.Container}} {{.CPUPerc}} {{.MemPerc}}
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root      8955 13.0  0.3  40972 26028 ?        Sl   09:55   0:00 docker stats --no-stream --format={{.Container}} {{.CPUPerc}} {{.MemPerc}}
I am running unRAID on a low power consumption based system backed by an Intel Celeron J3455 processor so I don't always have spare cycles -- this command finishes after approximately 0.6 seconds and starts almost immediately again 24/7 (based on what I can see with the PID constantly changing) and it is generating a little bit of a load on my load average outputs.  It nearly always consumes 10 to 13% of my CPU while running.
To remediate this, I would expect that this command should only run only when the docker page is being viewed on the Web UI, and ideally only if the advanced view is turned on as it is really only for informational needs.
