[6.9.0 6.9.1 ] Spinup Issues when connecting USB Device and Unassigned Devices installed [In RC2 also]
  • Minor
This issue is still happening as per rc2.
I have installed doron's SAS plugin to standardise on the approach rather than using my own sdspin and versions of smartctl.
Connecting a USB flash drive causes the parity drive(in my case) to spin up. But the ball stays grey and Unraid thinks it is spin spun down but it isn't. sdf is the parity drive, and sdl is the new usb stick plugged in.
All other drives stay spun down.
In UA dev2 gets missed out for some reason. If I click on the ball for parity changes to green an shows temp of 44C.
Existing RC2 post is at the bottom.
Mar 2 10:09:03 Tower emhttpd: spinning down /dev/sdb
Mar 2 10:20:36 Tower emhttpd: spinning down /dev/sdh
Mar 2 10:20:36 Tower emhttpd: spinning down /dev/sdg
Mar 2 10:20:36 Tower SAS Assist v0.85: Spinning down device /dev/sdg
Mar 2 10:20:36 Tower SAS Assist v0.85: Spinning down device /dev/sdh
Mar 2 10:20:37 Tower emhttpd: spinning down /dev/sdj
Mar 2 10:20:37 Tower emhttpd: spinning down /dev/sdk
Mar 2 10:20:37 Tower SAS Assist v0.85: Spinning down device /dev/sdj
Mar 2 10:20:37 Tower SAS Assist v0.85: Spinning down device /dev/sdk
Mar 2 10:20:38 Tower emhttpd: spinning down /dev/sdi
Mar 2 10:20:38 Tower SAS Assist v0.85: Spinning down device /dev/sdi
Mar 2 10:21:05 Tower emhttpd: spinning down /dev/sde
Mar 2 10:21:05 Tower emhttpd: spinning down /dev/sdf
Mar 2 10:21:05 Tower SAS Assist v0.85: Spinning down device /dev/sde
Mar 2 10:21:05 Tower SAS Assist v0.85: Spinning down device /dev/sdf
Mar 2 10:23:11 Tower kernel: usb 3-6: new high-speed USB device number 8 using xhci_hcd
Mar 2 10:23:11 Tower kernel: usb-storage 3-6:1.0: USB Mass Storage device detected
Mar 2 10:23:11 Tower kernel: scsi host10: usb-storage 3-6:1.0
Mar 2 10:23:12 Tower unraid.usbip-gui: Info: rc.unraid.usbip-gui usb_add USB_Flash_Drive_A5B8E821183F2D4F /dev/bus/usb/003/008 003 008
Mar 2 10:23:12 Tower unraid.usbip-gui: Info: rc.unraid.usbip-gui Autoconnect No Mapping found USB_Flash_Drive_A5B8E821183F2D4F /dev/bus/usb/003/008 003 008 port 3-6
Mar 2 10:23:12 Tower kernel: scsi 10:0:0:0: Direct-Access USB DISK V1.0 PQ: 0 ANSI: 2
Mar 2 10:23:12 Tower kernel: sd 10:0:0:0: Attached scsi generic sg11 type 0
Mar 2 10:23:12 Tower kernel: sd 10:0:0:0: [sdl] 4099168 512-byte logical blocks: (2.10 GB/1.95 GiB)
Mar 2 10:23:12 Tower kernel: sd 10:0:0:0: [sdl] Write Protect is off
Mar 2 10:23:12 Tower kernel: sd 10:0:0:0: [sdl] Mode Sense: 0b 00 00 08
Mar 2 10:23:12 Tower kernel: sd 10:0:0:0: [sdl] No Caching mode page found
Mar 2 10:23:12 Tower kernel: sd 10:0:0:0: [sdl] Assuming drive cache: write through
Mar 2 10:23:12 Tower kernel: sdl: sdl1
Mar 2 10:23:13 Tower kernel: sd 10:0:0:0: [sdl] Attached SCSI removable disk
Mar 2 10:23:13 Tower unassigned.devices: Disk with serial 'DISK_A5B8E821183F2D4F', mountpoint 'UBUNTU_18_0' is not set to auto mount.
Mar 2 10:23:20 Tower kernel: sd 2:0:1:0: attempting task abort!scmd(0x00000000f869ab6a), outstanding for 7065 ms & timeout 7000 ms
Mar 2 10:23:20 Tower kernel: sd 2:0:1:0: [sdf] tag#7126 CDB: opcode=0x12 12 01 00 00 fe 00
Mar 2 10:23:20 Tower kernel: scsi target2:0:1: handle(0x000e), sas_address(0x5000c500626c01e9), phy(2)
Mar 2 10:23:20 Tower kernel: scsi target2:0:1: enclosure logical id(0x5003048011c7eb00), slot(1)
Mar 2 10:23:20 Tower emhttpd: ST4000NM0023_35000c500626c01eb (sdf) 512 7814037168
Mar 2 10:23:20 Tower kernel: sd 2:0:1:0: task abort: SUCCESS scmd(0x00000000f869ab6a)
Mar 2 10:23:20 Tower emhttpd: USB_DISK_A5B8E821183F2D4F-0:0 (sdl) 512 4099168
Mar 2 10:23:20 Tower emhttpd: read SMART /dev/sdf
Mar 2 10:23:20 Tower emhttpd: read SMART /dev/sdl
Mar 2 10:38:21 Tower emhttpd: spinning down /dev/sdl
Mar 2 10:38:22 Tower emhttpd: read SMART /dev/sdl
Mar 2 10:53:24 Tower emhttpd: spinning down /dev/sdl
Mar 2 10:53:25 Tower emhttpd: read SMART /dev/sdl
RC2 post is here.
https://staging.forums.unraid.net/bug-reports/prereleases/disk-spin-up-r1174/?do=findComment&comment=12304&d=2&tab=comments
