Issue with cache/btrfs pool, errors on check, not sure what problem is
  • Closed
I was trying to copy some data to my cache drive and noticed that I was unable to write. It is a cache pool of two 500GB WD Black NVMEs in a mirrored pool
Looked in the logs and saw that cache was trying to write but was getting errors
Dec  9 20:41:15 Tower kernel: BTRFS error (device nvme0n1p1: state EA): parent transid verify failed on logical 1399619584 mirror 1 wanted 2502028 found 2502026
Decided to do a clean reboot, but saw in the logs that the server was waiting on cache to unmount and would not. (target is busy, error 32).
I have restarted in safe mode, put into maintenance, and run a btrfs check, with the following output.
Looking for some guidance on what steps to take.
[1/7] checking root items
[2/7] checking extents
tree extent[1096040448, 16384] root 18446612686404689040 has no tree block found
tree extent[1096040448, 16384] root 22180 has no backref item in extent tree
incorrect global backref count on 1096040448 found 3 wanted 2
backpointer mismatch on [1096040448 16384]
ref mismatch on [2257813504 32768] extent item 9836206978716663809, found 1
data extent[6303264768, 24576] bytenr mimsmatch, extent item bytenr 6303264768 file item bytenr 0
data extent[6303264768, 24576] referencer count mismatch (root 17843261723641926475 owner 281472971913761 offset 0) wanted 1 have 0
data extent[6303264768, 24576] referencer count mismatch (root 21323 owner 2055 offset 0) wanted 0 have 1
backpointer mismatch on [6303264768 24576]
ERROR: errors found in extent allocation tree or chunk allocation
[3/7] checking free space tree
free space info recorded 10473 extents, counted 10488
wanted offset 714981376, found 714960896
cache appears valid but isn't 22020096
free space info recorded 10546 extents, counted 10552
wanted bytes 688128, found 323584 for off 3533160448
cache appears valid but isn't 3276800000
[4/7] checking fs roots
[5/7] checking only csums items (without verifying data)
[6/7] checking root refs
[7/7] checking quota groups skipped (not enabled on this FS)
Opening filesystem to check...
Checking filesystem on /dev/nvme0n1p1
UUID: dc3c46b8-ae6c-403a-a905-84c2f0209c73
found 172622249984 bytes used, error(s) found
total csum bytes: 138954748
total tree bytes: 1306017792
total fs tree bytes: 1067319296
total extent tree bytes: 70434816
btree space waste bytes: 286745898
file data blocks allocated: 1380010901504
 referenced 162174189568
tower-diagnostics-20231209-2117.zip
EDIT: just trying to copy off of cache drive, watching log and this showed up
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 0 csum 0x8941f998 expected csum 0x99384b54 mirror 2
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme0n1p1 errs: wr 0, rd 0, flush 0, corrupt 9, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 4096 csum 0x8941f998 expected csum 0x154bd2df mirror 2
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme0n1p1 errs: wr 0, rd 0, flush 0, corrupt 10, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 8192 csum 0x8941f998 expected csum 0xb6cae9b5 mirror 2
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme0n1p1 errs: wr 0, rd 0, flush 0, corrupt 11, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 12288 csum 0x8941f998 expected csum 0xaef79424 mirror 2
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme0n1p1 errs: wr 0, rd 0, flush 0, corrupt 12, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 16384 csum 0x8941f998 expected csum 0xb8e34627 mirror 2
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme0n1p1 errs: wr 0, rd 0, flush 0, corrupt 13, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 20480 csum 0x8941f998 expected csum 0x05fedd1d mirror 2
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme0n1p1 errs: wr 0, rd 0, flush 0, corrupt 14, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 0 csum 0x8941f998 expected csum 0x99384b54 mirror 1
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme1n1p1 errs: wr 0, rd 0, flush 0, corrupt 9, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 4096 csum 0x8941f998 expected csum 0x154bd2df mirror 1
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 8192 csum 0x8941f998 expected csum 0xb6cae9b5 mirror 1
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme1n1p1 errs: wr 0, rd 0, flush 0, corrupt 10, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme1n1p1 errs: wr 0, rd 0, flush 0, corrupt 11, gen 0
Dec  9 21:45:38 Tower kernel: BTRFS warning (device nvme0n1p1: state EA): csum failed root 5 ino 10748423 off 12288 csum 0x8941f998 expected csum 0xaef79424 mirror 1
Dec  9 21:45:38 Tower kernel: BTRFS error (device nvme0n1p1: state EA): bdev /dev/nvme1n1p1 errs: wr 0, rd 0, flush 0, corrupt 12, gen 0
