Help with MCE error from Fix Common Problems
Anything listed in the system's event log in the bios?
Sorry, I’m not sure I know how to check it?
Edit: Did some searching. So I should reboot the server and enter bios? I’ve just been warned about rebooting the server after an error so was a little paranoid but I think I understand why it makes sense.
Edited by betaman
Ok, so I was able to check it but the system said the log is full and my last entry was from 2016. There was no clock in the UEFI shell so how do I know if my system time is correct or if I need a new battery? Anyway, I exported the log and cleared it. Should this be happening automatically or are you supposed to periodically do it?
Edited by betaman
