Home automation help
I have a smart plug which I think is flashable with tasmota, the plug does power monitoring as well.
What I would like to do is monitor for a power state change, say under 30watts, then send a notification to my Google home for it to say aloud or do some other action based on that state change.
What docker would I need to make this as straight forward as possible?
OTOH if no one has any better ideas, I would think that you're going to be investigating IFTTT (google it) and creating a rule for that.
If IFTTT could do that, it would be your best bet. Otherwise you can look at a smart hub (smartthings, home assistant, homeseer, etc). It would be a lot more work to set up but would do exactly what you're looking for and more.
I don't know if those can be run in a docker. I'm currently running homeseer in a VM.
