Starship/Matisse HD Audio Controller Problem (Realtek® S1220A)
I recently completed a Ryzen build for my new unraid server.
The System-Specs are:
Mainboard: Asus Pro WS X570-ACE
Audio Controller: Realtek® S1220A
CPU: AMD Ryzen 9 3950X
So i am able to pass through my GPU and other devices to the Windows 10 VM. The Audio Controller also works fine for several times, but often unfortunately the VM crashes and as soon as i restart it the controller wont work 100%.
I can use my microphone as normaly and the front audio panel inputs too, but the rear audio output wont play any sound. In the Realtek driver settings i can see that the audio devices is plugged in and also that theres sound beeing played but i cant hear anything beeing played.
It seems to be random because sometimes it works without a problem but then sometimes theres nothing i can do to get it to work.
i tried to reinstall driver, restart the vm and the computer but nothing changes.
Additional information:
The Audio Controller has its own IOMMU-Group
This is my VM-File:
<domain type='kvm' id='3'>
  <name>Player 1 Split</name>
  <uuid>f809ffc5-1273-b481-9785-908631b0b995</uuid>
  <description>6 Core 30 GB RAM</description>
  <metadata>
  </metadata>
  <memory unit='KiB'>31457280</memory>
  <currentMemory unit='KiB'>31457280</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>12</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='8'/>
    <vcpupin vcpu='1' cpuset='24'/>
    <vcpupin vcpu='2' cpuset='9'/>
    <vcpupin vcpu='3' cpuset='25'/>
    <vcpupin vcpu='4' cpuset='10'/>
    <vcpupin vcpu='5' cpuset='26'/>
    <vcpupin vcpu='6' cpuset='11'/>
    <vcpupin vcpu='7' cpuset='27'/>
    <vcpupin vcpu='8' cpuset='12'/>
    <vcpupin vcpu='9' cpuset='28'/>
    <vcpupin vcpu='10' cpuset='13'/>
    <vcpupin vcpu='11' cpuset='29'/>
  </cputune>
  <resource>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-i440fx-5.1'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/f809ffc5-1273-b481-9785-908631b0b995_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
      <vendor_id state='on' value='2D76A8B352F1'/>
    </hyperv>
    <kvm>
      <hidden state='on'/>
    </kvm>
    <ioapic driver='kvm'/>
  </features>
    <topology sockets='1' dies='1' cores='6' threads='2'/>
    <cache mode='passthrough'/>
    <feature policy='require' name='topoext'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/user/domains/Player 1 Split/vdisk1.img' index='1'/>
      <backingStore/>
      <boot order='1'/>
      <alias name='virtio-disk2'/>
    </disk>
    <controller type='usb' index='0' model='qemu-xhci' ports='15'>
      <alias name='usb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/>
    </controller>
      <alias name='sata0'/>
    </controller>
    <controller type='pci' index='0' model='pci-root'>
      <alias name='pci.0'/>
    </controller>
      <alias name='virtio-serial0'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:d4:0b:87'/>
      <source bridge='br0'/>
      <target dev='vnet0'/>
      <model type='virtio-net'/>
      <alias name='net0'/>
    </interface>
    <serial type='pty'>
      <source path='/dev/pts/0'/>
        <model name='isa-serial'/>
      </target>
      <alias name='serial0'/>
    </serial>
    <console type='pty' tty='/dev/pts/0'>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-3-Player 1 Split/org.qemu.guest_agent.0'/>
      <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/>
      <alias name='channel0'/>
    </channel>
    <input type='mouse' bus='ps2'>
      <alias name='input0'/>
    </input>
    <input type='keyboard' bus='ps2'>
      <alias name='input1'/>
    </input>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x0c' slot='0x00' function='0x0'/>
      </source>
      <alias name='hostdev0'/>
      <rom file='/mnt/user/isos/TitanXPUnraid.rom'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0c' slot='0x00' function='0x1'/>
      </source>
      <alias name='hostdev1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x1'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0f' slot='0x00' function='0x4'/>
      </source>
      <alias name='hostdev2'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x09' function='0x0'/>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='no'>
      <source>
        <vendor id='0x046d'/>
        <product id='0x081d'/>
        <address bus='2' device='2'/>
      </source>
      <alias name='hostdev3'/>
    </hostdev>
      <source>
        <product id='0xc539'/>
        <address bus='6' device='2'/>
      </source>
      <alias name='hostdev4'/>
      <address type='usb' bus='0' port='2'/>
    </hostdev>
      <source>
        <product id='0xc541'/>
        <address bus='6' device='3'/>
      </source>
      <alias name='hostdev5'/>
      <address type='usb' bus='0' port='3'/>
    </hostdev>
      <source>
        <vendor id='0x8087'/>
        <product id='0x0029'/>
        <address bus='2' device='6'/>
      </source>
      <alias name='hostdev6'/>
      <address type='usb' bus='0' port='4'/>
    </hostdev>
    <memballoon model='none'/>
  </devices>
  <seclabel type='dynamic' model='dac' relabel='yes'>
    <label>+0:+100</label>
    <imagelabel>+0:+100</imagelabel>
  </seclabel>
</domain>
Edited by alexthenumber1
  • alexthenumber1 changed the title to Starship/Matisse HD Audio Controller Problem (Realtek® S1220A)
