January 21, 20215 yr Hello, i was thinking to make my server silent as possible, mainly it's used for Plex By by some reason few of my drives (where is my media files are located) don't spin down. I used file File activity plugin, but it's not showing much information. Mostly it show me what all my media got accessed, probably by Plex. Which is the best practice to keep drives spinned down using SSD drives? I have 2 tb cache raid0 for downloads. How i can store recent media files on cache until it's close to be full to make my drives idling until i don't need data from them? Is it any hidden mover settings, like move when cache pool is almost full?
January 21, 20215 yr Does any of your appdata exist on the array drives. This is a very common reason drives not spinning down. Wouldn't hurt to post Diagnostics. To store on cache set your media shares to Cache: Yes to store recent files on the cache. You can setup Mover under settings and Scheduler to determine when these files get moved into the array. Edited January 21, 20215 yr by Gragorg
January 22, 20215 yr Author 20 hours ago, Gragorg said: Does any of your appdata exist on the array drives. This is a very common reason drives not spinning down. Wouldn't hurt to post Diagnostics. To store on cache set your media shares to Cache: Yes to store recent files on the cache. You can setup Mover under settings and Scheduler to determine when these files get moved into the array. In my understanding cache only should be working as you said, but not really. And also mover settings are not so flexible, in my opinion there should be some more flexibility to use it, but again, i am not that experienced user, so i can be wrong. Appdata is cache only, nothing on the array My spin down delay set to 15 min, but once drives start they never stop. I know few of them not in use, but still they spinning fortress-diagnostics-20210122-1316.zip
January 26, 20215 yr Author Ok apparently it was issue with ultimate dashboard, after i disabled all that dockers disk going to idle without any issues
