Help setting up raspberry pi as Wireguard Peer
My goal is the set up a remote backup server at a friend's house on a Raspberry Pi and connect to it via Wireguard. I have Wireguard working in unRAID which I use with the Android and windows clients but I'd like to set up a rasPi as a remote peer where I can access the local network at the remote location from my local network.
To do this would I add a new Tunnel in unRAID Wireguard settings, then create a config file and share that with the RasPi? Or would I just share the keys with the RasPi? Would LAN to LAN work for this config? Or do I create the config in the rasPi and share that with unRAID?
Has anyone set this up? It seems like it could be a very useful, inexpensive way to have a remote / off-site backup.
Edited by adminmat
  • 1 year later...
Hi @adminmat so did you succeed on your project?
