January 30, 20215 yr Over the last several weeks my Unraid server has had an issue where the CPU fan with go into turbo (loud) mode every 60-120 seconds and run at high speed for between 30 and 90 seconds at which point it will go silent again but will soon repeat. My CPU fan is a cooler master with 4 leads which means it's capable of IPMI control which I'm guessing is what's going on here. I however discovered that if I close down my PLEX docker the crazy fan stuff just stops but if I turn the PLEX back on the fan crazy stuff kicks back off again. I keep the PLEX docker updated and frankly it works fine but it does seem to cause this fan issue. Any thoughts...?
January 31, 20215 yr Author When I try to upload the diagnostic file I get a forum error saying I can only upload 25 files
January 31, 20215 yr Community Expert 11 minutes ago, rharvey said: When I try to upload the diagnostic file I get a forum error saying I can only upload 25 files The diagnostics is only 1 file (a zip file). Are you trying to do the contained files separately?
