Help! Low FPS on vm unraid gaming server using Threadripper 3960x and Nvidia GeForce Rtx 3080
Hi I am new to Unraid and trying to figure out what might be causing my poor gaming experience.  Gaming is shuttering and giving less than 10fps COD Black ops and other games.
Hardware:
Motherboard - Asus Rog Zenith II Extreme Alpha TRX40
Ram - Corsair Vengeance RGB Pro 64 GB
Harddrive - Samsung 970 EVO Plus SSD pcie nvme m.2 2TB
CPU - AMD Ryzen Threadripper 3960x 24 core
GPU - GigaByte  Aorus Gefore RTX 3080
Power Supply - Gigabyte GP -P850GM 850 W
OS - Windows 10 Pro
Unraid  Version: 6.9.0-rc1
GPU Passthrough Gigabyte.RTX3080.10240.201006.rom
XML VM Setup
<domain type='kvm' id='4'>
  <name>DerbyWin10</name>
  <uuid>8b994699-15ec-ed64-45ca-8734365c2f96</uuid>
  <metadata>
  </metadata>
  <memory unit='KiB'>21495808</memory>
  <currentMemory unit='KiB'>21495808</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>38</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='1'/>
    <vcpupin vcpu='1' cpuset='25'/>
    <vcpupin vcpu='2' cpuset='2'/>
    <vcpupin vcpu='3' cpuset='26'/>
    <vcpupin vcpu='4' cpuset='3'/>
    <vcpupin vcpu='5' cpuset='27'/>
    <vcpupin vcpu='6' cpuset='4'/>
    <vcpupin vcpu='7' cpuset='28'/>
    <vcpupin vcpu='8' cpuset='5'/>
    <vcpupin vcpu='9' cpuset='29'/>
    <vcpupin vcpu='10' cpuset='6'/>
    <vcpupin vcpu='11' cpuset='30'/>
    <vcpupin vcpu='12' cpuset='7'/>
    <vcpupin vcpu='13' cpuset='31'/>
    <vcpupin vcpu='14' cpuset='8'/>
    <vcpupin vcpu='15' cpuset='32'/>
    <vcpupin vcpu='16' cpuset='9'/>
    <vcpupin vcpu='17' cpuset='33'/>
    <vcpupin vcpu='18' cpuset='10'/>
    <vcpupin vcpu='19' cpuset='34'/>
    <vcpupin vcpu='20' cpuset='11'/>
    <vcpupin vcpu='21' cpuset='35'/>
    <vcpupin vcpu='22' cpuset='12'/>
    <vcpupin vcpu='23' cpuset='36'/>
    <vcpupin vcpu='24' cpuset='13'/>
    <vcpupin vcpu='25' cpuset='37'/>
    <vcpupin vcpu='26' cpuset='14'/>
    <vcpupin vcpu='27' cpuset='38'/>
    <vcpupin vcpu='28' cpuset='15'/>
    <vcpupin vcpu='29' cpuset='39'/>
    <vcpupin vcpu='30' cpuset='16'/>
    <vcpupin vcpu='31' cpuset='40'/>
    <vcpupin vcpu='32' cpuset='17'/>
    <vcpupin vcpu='33' cpuset='41'/>
    <vcpupin vcpu='34' cpuset='18'/>
    <vcpupin vcpu='35' cpuset='42'/>
    <vcpupin vcpu='36' cpuset='19'/>
    <vcpupin vcpu='37' cpuset='43'/>
  </cputune>
  <resource>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-i440fx-5.1'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/8b994699-15ec-ed64-45ca-8734365c2f96_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
    <topology sockets='1' dies='1' cores='19' threads='2'/>
    <cache mode='passthrough'/>
    <feature policy='require' name='topoext'/>
  </cpu>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/disks/main/vms/DerbyWin10/vdisk1.img' index='3'/>
      <backingStore/>
      <boot order='1'/>
      <alias name='virtio-disk2'/>
    </disk>
      <source file='/mnt/disks/main/isos/SW_DVD9_NTRL_Win_10_1903_64BIT_English_HomeProEDUSLS_N_X21-99935.ISO' index='2'/>
      <backingStore/>
      <target dev='hda' bus='ide'/>
      <readonly/>
      <boot order='2'/>
      <alias name='ide0-0-0'/>
    </disk>
      <source file='/mnt/disks/main/isos/virtio-win-0.1.190-1.iso' index='1'/>
      <backingStore/>
      <target dev='hdb' bus='ide'/>
      <readonly/>
      <alias name='ide0-0-1'/>
    </disk>
      <alias name='sata0'/>
    </controller>
      <alias name='virtio-serial0'/>
    </controller>
    <controller type='pci' index='0' model='pci-root'>
      <alias name='pci.0'/>
    </controller>
    <controller type='usb' index='0' model='qemu-xhci' ports='15'>
      <alias name='usb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/>
    </controller>
      <alias name='ide'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:b1:ef:ab'/>
      <source bridge='br0'/>
      <target dev='vnet2'/>
      <model type='virtio-net'/>
      <alias name='net0'/>
    </interface>
    <serial type='pty'>
      <source path='/dev/pts/2'/>
        <model name='isa-serial'/>
      </target>
      <alias name='serial0'/>
    </serial>
    <console type='pty' tty='/dev/pts/2'>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-4-DerbyWin10/org.qemu.guest_agent.0'/>
      <target type='virtio' name='org.qemu.guest_agent.0' state='connected'/>
      <alias name='channel0'/>
    </channel>
      <alias name='input0'/>
      <address type='usb' bus='0' port='1.4'/>
    </input>
    <input type='mouse' bus='ps2'>
      <alias name='input1'/>
    </input>
    <input type='keyboard' bus='ps2'>
      <alias name='input2'/>
    </input>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
      </source>
      <alias name='hostdev0'/>
      <rom file='/mnt/disks/main/isos/Gigabyte.RTX3080.10240.201006.rom'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x1'/>
      </source>
      <alias name='hostdev1'/>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='no'>
      <source>
        <vendor id='0x046d'/>
        <product id='0xc52b'/>
        <address bus='9' device='9'/>
      </source>
      <alias name='hostdev2'/>
      <address type='usb' bus='0' port='2'/>
    </hostdev>
      <source>
        <vendor id='0x0b05'/>
        <product id='0x18bb'/>
        <address bus='7' device='6'/>
      </source>
      <alias name='hostdev3'/>
      <address type='usb' bus='0' port='3'/>
    </hostdev>
      <source>
        <product id='0x18f3'/>
        <address bus='7' device='5'/>
      </source>
      <alias name='hostdev4'/>
      <address type='usb' bus='0' port='4'/>
    </hostdev>
      <source>
        <product id='0x1915'/>
        <address bus='9' device='11'/>
      </source>
      <alias name='hostdev5'/>
      <address type='usb' bus='0' port='5'/>
    </hostdev>
      <source>
        <product id='0x1916'/>
        <address bus='9' device='5'/>
      </source>
      <alias name='hostdev6'/>
      <address type='usb' bus='0' port='6'/>
    </hostdev>
      <source>
        <vendor id='0x1b1c'/>
        <product id='0x0c18'/>
        <address bus='7' device='2'/>
      </source>
      <alias name='hostdev7'/>
      <address type='usb' bus='0' port='7'/>
    </hostdev>
      <source>
        <vendor id='0x413c'/>
        <product id='0x5649'/>
        <address bus='5' device='2'/>
      </source>
      <alias name='hostdev8'/>
      <address type='usb' bus='0' port='8'/>
    </hostdev>
      <source>
        <vendor id='0x8087'/>
        <product id='0x0029'/>
        <address bus='7' device='4'/>
      </source>
      <alias name='hostdev9'/>
      <address type='usb' bus='0' port='9'/>
    </hostdev>
    <hub type='usb'>
      <alias name='hub0'/>
    </hub>
    <memballoon model='none'/>
  </devices>
  <seclabel type='dynamic' model='dac' relabel='yes'>
    <label>+0:+100</label>
    <imagelabel>+0:+100</imagelabel>
  </seclabel>
</domain>
Images:
I have the PCI-e as an unassigned Device and another WD Attached USB drive.  Not sure if these are setup properly.
I have a s limilar setup (3970x with 3 2080TIs) and also a spare (2950x with 3070 and 2080TI) and they all run games at very respectable frame rates.  The only real difference I see with your setup is the lack of passed through nvme (I have dedicated ones for each VM) and your clock setting is different.  I use the default xml code (basically just has hpet no hypervclock yes).  From what I've read clock settings can really influence Windows VM behavior.  Maybe something to check?  It seems mine are suboptimal but my results don't reflect that.
Try to put this section into you VM xml settings:
<features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
      <vpindex state='on'/>
      <synic state='on'/>
      <stimer state='on'/>
      <reset state='on'/>
      <vendor_id state='on' value='1234567890ab'/>
      <frequencies state='on'/>
    </hyperv>
    <kvm>
      <hidden state='on'/>
    </kvm>
    <vmport state='off'/>
    <ioapic driver='kvm'/>
  </features>
    <topology sockets='1' dies='1' cores='8' threads='1'/>
    <feature policy='require' name='svm'/>
    <feature policy='require' name='apic'/>
    <feature policy='require' name='hypervisor'/>
    <feature policy='require' name='invtsc'/>
  </cpu>
    <timer name='tsc' present='yes' mode='native'/>
  </clock>
<features>
    <acpi/>
    <apic/>
    <hyperv>
      <vapic state='on'/>
      <synic state='on'/>
      <reset state='on'/>
    </hyperv>
    <kvm>
    </kvm>
  </features>
  </cpu>
  </clock>
I am pretty sure I have used most of those settings before (not all) and I don't recall seeing any benefits although I never specifically measured FPS for example.  One thing I do note is the topology...what's up with that?  Certainly doesn't mirror the host CPU.
I ran the LatencyMon program and found that my display driver installed was causing a huge lag.  So I uninstalled the driver and installed the 3080 rtx windows driver.  Now i am getting much better results.  I also tried your cpu settings but they didn't seem to help much.
  • 9 months later...
 Hi All,
I am having issues with same setup where server keeps crashing all the time. "The Ryzen" issue where it just locks up.
Hardware
ROG Zenith II Extreme Alpha
AMD Ryzen Threadripper 3970x 32-Core
192GB DDR4 Corsair Vengeance Pro (256GB Kit, the other 64GB is in my Intel Server)
NVIDIA Quadro RTX 4000
Additional 1GB NIC Realtek RTL8111
ROG RYUJIN 360 AIO Water Cooler
ASUS Hyper M.2 X16 Gen 4 RAID Controller Card with 4 x 1TB Samsung 980 Pro Gen 4
1TB Samsung 980 Pro on the Board Gen 4
1TB Samsung 980 Gen 3 UnAssigned
1TB Samsung 980 Gen 3 as Parity
So the even when the array is not mounted or doing anything it becomes unresponsive and a hard power down to restart fixes it.
I have disabled C States, I have put in rcu_nocbs=0-63 in the config and nothing has helped so far. I have run this machine under Windows for a week and the hardware is stable, no crashes and get the full performance. So i am guessing its something to do  with my BIOS or UnRAID server settings.
I am tempted to sell it and get 6 Beast Canyon NUCs. So they can each do my work in pieces.
