February 11, 20215 yr Hello, The issue started while i was trying to know my real network speed (Wifi) and the potential need for an upgrade to Wifi 6 ... I installed openspeed test network and got a wifi speed about 600Mbits/s from my macbook air m1. To be sure, I tried the same from a windows VM on Bridge with a discrete IP from the server and got a 980Mbits/s up and down. So for sure I have only a gigabit network, so I assume the connection from the VM to the server (which has another IP) is going through the router ? I tried to validate the results by doing an Iperf from the VM to a Iperf3 docker, and got a 7Gb/s - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth [ 4] 0.00-10.00 sec 8.56 GBytes 7.35 Gbits/sec sender [ 4] 0.00-10.00 sec 8.56 GBytes 7.35 Gbits/sec receiver When I doing a file transfer from the VM to the Unraid Cache, I'm getting between 800MB/s and 900MB/s , so also almost a 10Gb/s connection, saturating the M.2 SSD This is concistent because the VM in on the host on a virtual adapter. So but I do not understand why the Openspeedtest is limited to 1Gb/s PS, I tried an Iperf3 from the unraid command line to the iperf3 docker, and got over 50Gb/s
