Extended Test with Fix Common Problems
I keep getting the warning about the following files/folders may not be accessible to SMB shares. While I was setting up Nextcloud, I had the SMB share set to yes. However I have since changed this to no. I've tried enabling it again, and disabling. I even changed the permissions of the root directory for nextcloud to match my other shares. I have run Docker Safe New Perms several times as well. I cannot seem to figure out how to clear this warning. Any ideas? Other than just excluding the directory from Fix Common Problems?
