Constant hardware errors from Fix Common Problems
hey all, I recently upgraded the board in my server to an ASRock Z590 and the processor to a Core i5-10400.
Ever since then I am getting constant popups from the Fix Common Problems plugin saying that a hardware error has been detected. Mcelog outputs the following:
mcelog: Family 6 Model 165 CPU: only decoding architectural errors
mcelog: warning: 8 bytes ignored in each record
mcelog: consider an update
The hardware seems to be running alright but I've included a diagnostic report as well.
Does someone know what's going on and if I need to be worried?
Thanks!
watchtower-diagnostics-20210505-2012.zip
I've had limited experience with non-fatal mce errors (ie, most of my mce errors have historically been crash-causing) but immediate suspects;
- Overclocking (XMP is overclocking) - turn it off if you're overclocking.
- BIOS/microcode updates - check your motherboard support website for updates and apply them carefully.
- Not sure if related, but during loading/init of the Intel GPU modeules, your kernel explodes -- very likely to be worthwhile to disable this, if you can.
Spoiler
May  4 15:36:34 Watchtower root: ---------Enabling Intel Kernel Module----------
May  4 15:36:34 Watchtower kernel: Linux agpgart interface v0.103
May  4 15:36:34 Watchtower kernel: ------------[ cut here ]------------
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: drm_WARN_ON(!IS_PLATFORM(dev_priv, INTEL_TIGERLAKE) && !IS_PLATFORM(dev_priv, INTEL_ROCKETLAKE))
May  4 15:36:34 Watchtower kernel: WARNING: CPU: 11 PID: 5292 at drivers/gpu/drm/i915/intel_pch.c:123 intel_pch_type+0x86e/0x8d3 [i915]
May  4 15:36:34 Watchtower kernel: Modules linked in: i915(+) iosf_mbi i2c_algo_bit drm_kms_helper drm intel_gtt agpgart syscopyarea sysfillrect sysimgblt fb_sys_fops nct6775 hwmon_vid iptable_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 wireguard curve25519_x86_64 libcurve25519_generic libchacha20poly1305 chacha_x86_64 poly1305_x86_64 ip6_udp_tunnel udp_tunnel libblake2s blake2s_x86_64 libblake2s_generic libchacha ip6table_filter ip6_tables iptable_filter ip_tables x_tables intel_wmi_thunderbolt wmi_bmof x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel crypto_simd cryptd btusb btrtl btbcm glue_helper btintel rapl i2c_i801 intel_cstate bluetooth nvme ahci i2c_smbus intel_uncore nvme_core i2c_core libahci e1000e input_leds ecdh_generic led_class ecc video wmi backlight button acpi_pad
May  4 15:36:34 Watchtower kernel: CPU: 11 PID: 5292 Comm: modprobe Not tainted 5.10.28-Unraid #1
May  4 15:36:34 Watchtower kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./Z590 Phantom Gaming 4/ac, BIOS P1.30 02/01/2021
May  4 15:36:34 Watchtower kernel: RIP: 0010:intel_pch_type+0x86e/0x8d3 [i915]
May  4 15:36:34 Watchtower kernel: Code: 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 ca 40 ff e0 48 c7 c1 ea 1b 54 a0 4c 89 e2 48 c7 c7 4e 15 54 a0 48 89 c6 e8 2c 9e 25 e1 <0f> 0b b8 09 00 00 00 eb 58 48 8b 7b 18 48 c7 c2 4b 1c 54 a0 be 04
May  4 15:36:34 Watchtower kernel: RSP: 0018:ffffc9000114f9f0 EFLAGS: 00010286
May  4 15:36:34 Watchtower kernel: RAX: 0000000000000000 RBX: ffff888145780000 RCX: 0000000000000027
May  4 15:36:34 Watchtower kernel: RDX: 00000000ffffefff RSI: 0000000000000001 RDI: ffff8886648d8920
May  4 15:36:34 Watchtower kernel: RBP: ffff888145784385 R08: 0000000000000000 R09: 00000000ffffefff
May  4 15:36:34 Watchtower kernel: R10: ffffc9000114f820 R11: ffffc9000114f818 R12: ffff888101ac4760
May  4 15:36:34 Watchtower kernel: R13: 0000000045784380 R14: ffff888145786eb8 R15: ffff888145786d70
May  4 15:36:34 Watchtower kernel: FS:  00001537c1288740(0000) GS:ffff8886648c0000(0000) knlGS:0000000000000000
May  4 15:36:34 Watchtower kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May  4 15:36:34 Watchtower kernel: CR2: 000000000105e918 CR3: 0000000138340005 CR4: 00000000007706e0
May  4 15:36:34 Watchtower kernel: PKRU: 55555554
May  4 15:36:34 Watchtower kernel: Call Trace:
May  4 15:36:34 Watchtower kernel: intel_detect_pch+0x6b/0x22f [i915]
May  4 15:36:34 Watchtower kernel: i915_driver_probe+0x270/0xb32 [i915]
May  4 15:36:34 Watchtower kernel: ? rpm_resume+0x9a/0x3d6
May  4 15:36:34 Watchtower kernel: i915_pci_probe+0xf8/0x118 [i915]
May  4 15:36:34 Watchtower kernel: ? _raw_spin_unlock_irqrestore+0xd/0xe
May  4 15:36:34 Watchtower kernel: ? __pm_runtime_resume+0x64/0x71
May  4 15:36:34 Watchtower kernel: local_pci_probe+0x3c/0x7a
May  4 15:36:34 Watchtower kernel: pci_device_probe+0x140/0x19a
May  4 15:36:34 Watchtower kernel: ? sysfs_do_create_link_sd.isra.0+0x6b/0x98
May  4 15:36:34 Watchtower kernel: really_probe+0x157/0x341
May  4 15:36:34 Watchtower kernel: driver_probe_device+0x63/0x92
May  4 15:36:34 Watchtower kernel: device_driver_attach+0x37/0x50
May  4 15:36:34 Watchtower kernel: __driver_attach+0x95/0x9d
May  4 15:36:34 Watchtower kernel: ? device_driver_attach+0x50/0x50
May  4 15:36:34 Watchtower kernel: bus_for_each_dev+0x70/0xa6
May  4 15:36:34 Watchtower kernel: bus_add_driver+0xfe/0x1af
May  4 15:36:34 Watchtower kernel: driver_register+0x99/0xd2
May  4 15:36:34 Watchtower kernel: ? 0xffffffffa05e4000
May  4 15:36:34 Watchtower kernel: i915_init+0x58/0x6b [i915]
May  4 15:36:34 Watchtower kernel: do_one_initcall+0x71/0x162
May  4 15:36:34 Watchtower kernel: ? do_init_module+0x19/0x1eb
May  4 15:36:34 Watchtower kernel: ? kmem_cache_alloc+0x108/0x130
May  4 15:36:34 Watchtower kernel: do_init_module+0x51/0x1eb
May  4 15:36:34 Watchtower kernel: load_module+0x1b18/0x20cf
May  4 15:36:34 Watchtower kernel: ? map_kernel_range_noflush+0xdf/0x255
May  4 15:36:34 Watchtower kernel: ? __do_sys_init_module+0xc4/0x105
May  4 15:36:34 Watchtower kernel: ? _cond_resched+0x1b/0x1e
May  4 15:36:34 Watchtower kernel: __do_sys_init_module+0xc4/0x105
May  4 15:36:34 Watchtower kernel: do_syscall_64+0x5d/0x6a
May  4 15:36:34 Watchtower kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
May  4 15:36:34 Watchtower kernel: RIP: 0033:0x1537c13cb09a
May  4 15:36:34 Watchtower kernel: Code: 48 8b 0d f9 7d 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c6 7d 0c 00 f7 d8 64 89 01 48
May  4 15:36:34 Watchtower kernel: RSP: 002b:00007fffcf1b7de8 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
May  4 15:36:34 Watchtower kernel: RAX: ffffffffffffffda RBX: 0000000000429e40 RCX: 00001537c13cb09a
May  4 15:36:34 Watchtower kernel: RDX: 000000000041c368 RSI: 00000000002fa9b8 RDI: 0000000000d63f60
May  4 15:36:34 Watchtower kernel: RBP: 0000000000d63f60 R08: 000000000042701a R09: 0000000000000000
May  4 15:36:34 Watchtower kernel: R10: 0000000000427010 R11: 0000000000000246 R12: 000000000041c368
May  4 15:36:34 Watchtower kernel: R13: 0000000000000000 R14: 0000000000429f50 R15: 0000000000429e40
May  4 15:36:34 Watchtower kernel: ---[ end trace 59cc9b3ebf49a875 ]---
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: [drm] VT-d active for gfx access
May  4 15:36:34 Watchtower kernel: checking generic (80000000 7e9000) vs hw (a2000000 1000000)
May  4 15:36:34 Watchtower kernel: checking generic (80000000 7e9000) vs hw (80000000 10000000)
May  4 15:36:34 Watchtower kernel: fb0: switching to inteldrmfb from EFI VGA
May  4 15:36:34 Watchtower kernel: Console: switching to colour dummy device 80x25
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: [drm] *ERROR* crtc 51: Can't calculate constants, dotclock = 0!
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: drm_WARN_ON_ONCE(drm_drv_uses_atomic_modeset(dev))
May  4 15:36:34 Watchtower kernel: WARNING: CPU: 11 PID: 5292 at drivers/gpu/drm/drm_vblank.c:722 drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x125/0x2a1 [drm]
May  4 15:36:34 Watchtower kernel: CPU: 11 PID: 5292 Comm: modprobe Tainted: G        W         5.10.28-Unraid #1
May  4 15:36:34 Watchtower kernel: RIP: 0010:drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x125/0x2a1 [drm]
May  4 15:36:34 Watchtower kernel: Code: 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 74 5c 06 e1 48 c7 c1 b0 bb 3f a0 4c 89 ea 48 c7 c7 d7 b2 3f a0 48 89 c6 e8 d6 b9 2c e1 <0f> 0b e9 4d 01 00 00 41 57 48 8d 55 b0 48 8b 45 90 4c 89 f7 89 75
May  4 15:36:34 Watchtower kernel: RSP: 0018:ffffc9000114f7d0 EFLAGS: 00010086
May  4 15:36:34 Watchtower kernel: RBP: ffffc9000114f840 R08: 0000000000000000 R09: 00000000ffffefff
May  4 15:36:34 Watchtower kernel: R10: ffffc9000114f600 R11: ffffc9000114f5f8 R12: 0000000000000000
May  4 15:36:34 Watchtower kernel: R13: ffff888101ac4760 R14: ffff8881012d2000 R15: ffff88810560d4a8
May  4 15:36:34 Watchtower kernel: ? __intel_get_crtc_scanline+0x19f/0x19f [i915]
May  4 15:36:34 Watchtower kernel: ? drm_property_destroy+0xb3/0xb3 [drm]
May  4 15:36:34 Watchtower kernel: drm_get_last_vbltimestamp+0x8b/0xab [drm]
May  4 15:36:34 Watchtower kernel: drm_reset_vblank_timestamp+0x58/0xc0 [drm]
May  4 15:36:34 Watchtower kernel: ? drm_vblank_get+0xc2/0xcf [drm]
May  4 15:36:34 Watchtower kernel: drm_crtc_vblank_on+0xaf/0x10c [drm]
May  4 15:36:34 Watchtower kernel: intel_modeset_setup_hw_state+0x845/0x11ae [i915]
### [PREVIOUS LINE REPEATED 1 TIMES] ###
May  4 15:36:34 Watchtower kernel: ? ww_mutex_lock+0x10/0x73
May  4 15:36:34 Watchtower kernel: ? drm_modeset_lock_all_ctx+0x81/0xc7 [drm]
May  4 15:36:34 Watchtower kernel: intel_modeset_init_nogem+0x1113/0x1707 [i915]
May  4 15:36:34 Watchtower kernel: ? intel_irq_postinstall+0x40a/0x506 [i915]
May  4 15:36:34 Watchtower kernel: i915_driver_probe+0x885/0xb32 [i915]
May  4 15:36:34 Watchtower kernel: ---[ end trace 59cc9b3ebf49a876 ]---
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: drm_WARN_ON(!pll->info->funcs->get_hw_state(dev_priv, pll, &pipe_config->dpll_hw_state))
May  4 15:36:34 Watchtower kernel: WARNING: CPU: 11 PID: 5292 at drivers/gpu/drm/i915/display/intel_display.c:11160 hsw_get_pipe_config+0x88f/0xd34 [i915]
May  4 15:36:34 Watchtower kernel: RIP: 0010:hsw_get_pipe_config+0x88f/0xd34 [i915]
May  4 15:36:34 Watchtower kernel: Code: 85 d2 75 03 48 8b 17 48 89 14 24 e8 ba 1b f8 e0 48 8b 14 24 48 c7 c1 92 37 55 a0 48 c7 c7 e7 f8 54 a0 48 89 c6 e8 1b 79 1e e1 <0f> 0b 41 80 be ca 06 00 00 08 77 57 41 83 ff 04 75 51 49 81 c6 08
May  4 15:36:34 Watchtower kernel: RSP: 0018:ffffc9000114f740 EFLAGS: 00010286
May  4 15:36:34 Watchtower kernel: RAX: 0000000000000000 RBX: ffff888145799000 RCX: 0000000000000027
May  4 15:36:34 Watchtower kernel: RBP: ffff888145780000 R08: 0000000000000000 R09: 00000000ffffefff
May  4 15:36:34 Watchtower kernel: R10: ffffc9000114f570 R11: ffffc9000114f568 R12: ffff8881012d2000
May  4 15:36:34 Watchtower kernel: R13: 0000000000000202 R14: ffff888145780000 R15: 0000000000000001
May  4 15:36:34 Watchtower kernel: ? __intel_display_power_put_domain+0x15/0x126 [i915]
May  4 15:36:34 Watchtower kernel: ? ktime_get_mono_fast_ns+0x61/0x7d
May  4 15:36:34 Watchtower kernel: ? skl_ddi_pll_get_hw_state+0xa2/0xb0 [i915]
May  4 15:36:34 Watchtower kernel: ? verify_single_dpll_state.isra.0+0x79/0x27d [i915]
May  4 15:36:34 Watchtower kernel: intel_atomic_commit_tail+0xc1d/0x101e [i915]
May  4 15:36:34 Watchtower kernel: ? flush_workqueue+0x29b/0x2bf
May  4 15:36:34 Watchtower kernel: intel_atomic_commit+0x272/0x280 [i915]
May  4 15:36:34 Watchtower kernel: intel_modeset_init+0x106/0x1b8 [i915]
May  4 15:36:34 Watchtower kernel: i915_driver_probe+0x8b1/0xb32 [i915]
May  4 15:36:34 Watchtower kernel: ---[ end trace 59cc9b3ebf49a877 ]---
May  4 15:36:34 Watchtower kernel: crtc active state doesn't match with hw state (expected 0, found 1)
May  4 15:36:34 Watchtower kernel: WARNING: CPU: 4 PID: 5292 at drivers/gpu/drm/i915/display/intel_display.c:14330 intel_atomic_commit_tail+0xc73/0x101e [i915]
May  4 15:36:34 Watchtower kernel: CPU: 4 PID: 5292 Comm: modprobe Tainted: G        W         5.10.28-Unraid #1
May  4 15:36:34 Watchtower kernel: RIP: 0010:intel_atomic_commit_tail+0xc73/0x101e [i915]
May  4 15:36:34 Watchtower kernel: Code: b5 48 01 00 00 0f b6 90 48 01 00 00 40 38 d6 74 1b 80 3d 02 9e 0e 00 00 48 c7 c7 53 4d 55 a0 0f 84 97 03 00 00 e8 64 0d 1e e1 <0f> 0b 41 0f b6 97 ec 03 00 00 0f b6 b5 48 01 00 00 40 38 f2 74 1b
May  4 15:36:34 Watchtower kernel: RSP: 0018:ffffc9000114f8c8 EFLAGS: 00010282
May  4 15:36:34 Watchtower kernel: RAX: 0000000000000000 RBX: ffff8881012d5000 RCX: 0000000000000027
May  4 15:36:34 Watchtower kernel: RDX: 00000000ffffefff RSI: 0000000000000001 RDI: ffff888664718920
May  4 15:36:34 Watchtower kernel: RBP: ffff88814579d000 R08: 0000000000000000 R09: 00000000ffffefff
May  4 15:36:34 Watchtower kernel: R10: ffffc9000114f6f8 R11: ffffc9000114f6f0 R12: ffff8881012d5000
May  4 15:36:34 Watchtower kernel: R13: ffff888145780000 R14: ffff888145780000 R15: ffff8881012d2000
May  4 15:36:34 Watchtower kernel: FS:  00001537c1288740(0000) GS:ffff888664700000(0000) knlGS:0000000000000000
May  4 15:36:34 Watchtower kernel: CR2: 0000000000673158 CR3: 0000000138340002 CR4: 00000000007706e0
May  4 15:36:34 Watchtower kernel: ---[ end trace 59cc9b3ebf49a878 ]---
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
May  4 15:36:34 Watchtower kernel: [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
May  4 15:36:34 Watchtower kernel: ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
May  4 15:36:34 Watchtower kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10
May  4 15:36:34 Watchtower kernel: i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
May  4 15:36:34 Watchtower root: ---Intel Kernel Module successfully enabled!---
Edited by codefaux
