BIOS CPU temps reported low, but CPU temps high when booted into Unraid
Hello!
Recently, i've been having this weird issue where my CPU temperatures keep getting reported as very high (80c).
When I am in the ASUS BIOS, it reports it as normal (30c), its just when I boot into the Unraid dashboard that it becomes an issue.
I've reseated the CPU fan multiple times, but it keeps coming up with the same issue.
I attached the diagnostics report. Any help would be wonderful. Thank you!
tower-diagnostics-20210510-0830.zip
CPU temps are not a stock feature, you should post instead on the support thread of the plugin you're using.
Thank you JorgeB I will do that just to be sure.
An update though, I went into Dynamix System Temperature, and unloaded and reloaded the drivers. After that, I correctly set the processor that was to be used. Seems like all is well now.
