May 15, 20215 yr Hi, Unraid 6.9.2 told me that the flash drive is faulty. I was still able to do a backup. The restore to a new stick does not work as expected. The server starts up. The server cannot be reached via the browser. The SSH connection is working. I come to the server. The hard drives are not accessible to "me". What are my options? I enclosed the diagnostic run. Thank you for your help. Edited May 16, 20215 yr by mkxtty Solved
May 15, 20215 yr Community Expert According to the diagnostics the system had not finished initialising at the point the diagnostics were taken, so not much in the way of conclusions can be drawn.
May 15, 20215 yr Author Thanks for the quick response. I started the diagnosis again. The zip file is created relatively quickly. More does not come out. Edited May 16, 20215 yr by mkxtty
May 16, 20215 yr Author Hello JorgeB, that seems to have been it! THANKS. I installed a completely new system and started with the important super.dat file and the configuration for the hard drives and users on the new Stick. Unraid then ran really high. The web server was accessible / login was possible. The hard drives were also all available. After that was done, the rest of the configs were installed. I did not use the GO file from the corrupt USB backup. Thank you again! Greetings M.
