URGENT: Monitor fans' speed?
I am saying it is urgent because I would like to see the status of my server that is remote and it is a bit dangerous to leave on if there is an issue.
My wife hears what by the description seems like a fan "wrestling" to work and a BIOS alarm probably about this very thing.
So, is there a way to monitor the fans of the system (obviously the ones that the system IS aware off, like CPU fan)?
Fan monitoring is not part of standard Unraid, but have you tried using the Dynamix System Autofan plugin?
Yes. Doesn't detect any PWM.
My motherboard is a pretty standard chipset Gigabyte Z87-HD3. I expected it would be an easy job.
No idea then :(  Have you tried asking in the support thread for that plugin if anyone else has succeeded with a similar setup.
also no PWM detected on my ASRock H470M-ITX/ac,
no fan control
Yes.
No response (yet).
  • 8 months later...
On 5/17/2021 at 4:01 AM, NLS said:
Yes.
No response (yet).
Sorry for the late reply, but did you get a solution?
No so I stopped trying to use this, long ago.
