June 12, 20215 yr A strange issue started recently... the docker imagers will not restart.. like I can not clikc on them and select restart, or stop them and then try to start them... they just error with a 404 error.. Any ideas?
June 12, 20215 yr If you've got the docker folders plugin installed, try uninstalling, reboot. If that fixes it post in its support thread
July 16, 20215 yr Author I do not know what is happening... basically I waited until the next time the dockers all needed to be updated, as that was when the errors happened but this time the error didn't happen.. so... "yay.. it is fixed... I guess".... thanks for your help and the into about the diagnostics... next time i have an issue I will use that.
