Need help troubleshooting "Machine check events" (solved)
Hi guys,
So I've been troubleshooting my server for over a month now, and I can't figure this out.
My server is randomly rebooting, and throwing "Machine check events detected" error in my logs...
I have successfully completed a memtest today, and the random reboots happens when the server is without load (and under load), so I think the powersupply and memory is fine...?
I don't know what information to supply here, so I'll attatch my logs and diagnostics...
Thanks in advance for any help! :)
tower-diagnostics-20210618-1857.zip tower-syslog-20210618-1648.zip
Edited by Alexander.Pettersson
See here, make sure it's using the correct "power supply idle" setting.
Thank you! This setting was set to automatic, and I’ve now changed it to «typical current idle». Been running without any random reboots since last night, so fingers crossed 😁
  • Alexander.Pettersson changed the title to Need help troubleshooting "Machine check events" (solved)
