September 9, 20214 yr Community Expert 1 hour ago, Gsusking2 said: backplane might have fried them Make sure you don't have a molex plugged in backwards. Seems impossible but it has happened.
September 9, 20214 yr Author 7 minutes ago, trurl said: Make sure you don't have a molex plugged in backwards. Seems impossible but it has happened. Yes I have tried that. I have 2 chassis and a lot of spare external hba and internal hba. so I have tried the disks across 2 chassis with the same problems on the same disks. more disks show up on my spare chassis so it has lead me to believe it is a backplane problem with the norco 4024 chassis.
September 9, 20214 yr Author 1 hour ago, JorgeB said: You can do a new config to keep the data in the remaing data drives. Ok. I’m gonna test the drives one last time on a driver reader that I bought from Amazon. From there I will ask you how to do the new config. I want to say I appreciate everything and everyone in this forum. It’s really great how you guys help us newbs
September 13, 20214 yr Author On 9/9/2021 at 9:43 AM, JorgeB said: You can do a new config to keep the data in the remaing data drives. can you tell me how to do that?
September 13, 20214 yr Community Expert Tools -> New config Then just re-assign the remaining drives, parity will need to be synced.
September 13, 20214 yr Author 9 hours ago, JorgeB said: Tools -> New config Then just re-assign the remaining drives, parity will need to be synced. I will only have one parity drive. Since one of my parity drives is 'missing/dead' Also I am still having the original problem of the Red X on drive 1 and 9, Both are present before i start the array. Can these also be repaired? or will they be emulated from the one pairty?
September 13, 20214 yr Community Expert 36 minutes ago, Gsusking2 said: Also I am still having the original problem of the Red X on drive 1 and 9, Both are present before i start the array. Only if the actual disks are OK, any emulated disks will be gone after a new config.
September 13, 20214 yr Author 29 minutes ago, JorgeB said: Only if the actual disks are OK, any emulated disks will be gone after a new config. Ok when doing new config do I “preserve any current assignments” ? again I really appreciate your help
September 13, 20214 yr Community Expert 9 minutes ago, Gsusking2 said: Ok when doing new config do I “preserve any current assignments” ? again I really appreciate your help That is optional as long as you end up with the correct assignments before starting the array I normally recommend using it to minimise the number of changes required when you return to the Main tab thus reducing the chances of making an error in the assignments.
