June 23, 20215 yr Hi guys I updated my gaming machine with a threadripper, unfortunately the GPU passthrough from the 1st GFK is no longer possible ... can someone help me? Specs: M/B: ASUSTeK COMPUTER INC. Pro WS WRX80E-SAGE SE WIFI Version Rev 1.xx - s/n: 210483465700039 BIOS: American Megatrends Inc. Version 0405. Dated: 03/17/2021 CPU: AMD Ryzen Threadripper PRO 3955WX 16-Cores @ 3900 MHz HVM: Enabled IOMMU: Enabled Cache: 1 MB, 8 MB, 64 MB Memory: 128 GiB DDR4 (max. installable capacity 512 GiB) GFK: 4x RTX 2060 EVO and 1x GT 710 use case: A 4 player couch gaming machine like an X-Box The GT 710 GFK combines the 4 images into one via NDI streams. Problem: The top GFK (slot 1) installed on the MB does not want to start since the change from an i9-9900K Error message on the VM Log: pci,host=0000:41:00.0,id=hostdev0,bus=pci.0,addr=0x6: Failed to mmap 0000:41:00.0 BAR 1. Performance may be slow 2021-06-23T16:07:48.918447Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3 XML: <?xml version='1.0' encoding='UTF-8'?> <domain type='kvm'> <name>Game_1</name> <uuid>c6a0f7ea-92a5-9e75-c7f8-f127a7994073</uuid> <metadata> <vmtemplate xmlns="unraid" name="Windows 10" icon="windows.png" os="windows10"/> </metadata> <memory unit='KiB'>24641536</memory> <currentMemory unit='KiB'>24641536</currentMemory> <memoryBacking> <nosharepages/> </memoryBacking> <vcpu placement='static'>6</vcpu> <cputune> <vcpupin vcpu='0' cpuset='0'/> <vcpupin vcpu='1' cpuset='16'/> <vcpupin vcpu='2' cpuset='1'/> <vcpupin vcpu='3' cpuset='17'/> <vcpupin vcpu='4' cpuset='2'/> <vcpupin vcpu='5' cpuset='18'/> </cputune> <os> <type arch='x86_64' machine='pc-i440fx-5.1'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader> <nvram>/etc/libvirt/qemu/nvram/c6a0f7ea-92a5-9e75-c7f8-f127a7994073_VARS-pure-efi.fd</nvram> </os> <features> <acpi/> <apic/> <hyperv> <relaxed state='on'/> <vapic state='on'/> <spinlocks state='on' retries='8191'/> <vendor_id state='on' value='none'/> </hyperv> </features> <cpu mode='host-passthrough' check='none' migratable='on'> <topology sockets='1' dies='1' cores='3' threads='2'/> <cache mode='passthrough'/> <feature policy='require' name='topoext'/> </cpu> <clock offset='localtime'> <timer name='hypervclock' present='yes'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/user/domains/Game_1/vdisk.img'/> <target dev='hdc' bus='virtio'/> <boot order='1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/> </disk> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/user/domains/Game_1/vdisk2.img'/> <target dev='hdd' bus='virtio'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/> </disk> <disk type='file' device='cdrom'> <driver name='qemu' type='raw'/> <source file='/mnt/user/isos/virtio-win-0.1.190-1.iso'/> <target dev='hdb' bus='ide'/> <readonly/> <address type='drive' controller='0' bus='0' target='0' unit='1'/> </disk> <controller type='pci' index='0' model='pci-root'/> <controller type='ide' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/> </controller> <controller type='virtio-serial' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/> </controller> <controller type='usb' index='0' model='ich9-ehci1'> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x7'/> </controller> <controller type='usb' index='0' model='ich9-uhci1'> <master startport='0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0' multifunction='on'/> </controller> <controller type='usb' index='0' model='ich9-uhci2'> <master startport='2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x1'/> </controller> <controller type='usb' index='0' model='ich9-uhci3'> <master startport='4'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x2'/> </controller> <interface type='bridge'> <mac address='52:54:00:15:0a:5f'/> <source bridge='br0'/> <model type='virtio-net'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/> </interface> <serial type='pty'> <target type='isa-serial' port='0'> <model name='isa-serial'/> </target> </serial> <console type='pty'> <target type='serial' port='0'/> </console> <channel type='unix'> <target type='virtio' name='org.qemu.guest_agent.0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='tablet' bus='usb'> <address type='usb' bus='0' port='1'/> </input> <input type='mouse' bus='ps2'/> <input type='keyboard' bus='ps2'/> <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='de-ch'> <listen type='address' address='0.0.0.0'/> </graphics> <video> <model type='qxl' ram='65536' vram='65536' vgamem='16384' heads='1' primary='yes'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/> </video> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x41' slot='0x00' function='0x0'/> </source> <rom file='/mnt/user/isos/vbios/218088.rom'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/> </hostdev> <memballoon model='none'/> </devices> </domain> i Have also atached the Diagnostics and the Syslog (with cleaning it overfilled) therealbeast-diagnostics-20210623-1757.zip syslog
July 22, 20215 yr Hello, I am experiencing the same issue, but with proxmox as a hypervisor instead of unraid. I posted this issue on the level1techs forum, https://forum.level1techs.com/t/vfio-passthrough-issues-threadripper-pro-asus-wrx80e-sage/173542 I have updated BIOS & BMC with no luck. I do not yet know of a solution to this. --- Something worthy of note: When I attempt to pass a graphics card through a slot 2-7 that has been bifurcated to 4x4x4x4x, but my graphics card is touching all 16x pins, I get the same error. I verified in my BIOS the top slot is not bifurcated, so I'm wondering if there's some oopsies in the firmware regarding bifurcation of that top slot.
July 30, 20215 yr On 6/23/2021 at 8:08 PM, Putschgi said: Hi guys I updated my gaming machine with a threadripper, unfortunately the GPU passthrough from the 1st GFK is no longer possible ... can someone help me? Specs: M/B: ASUSTeK COMPUTER INC. Pro WS WRX80E-SAGE SE WIFI Version Rev 1.xx - s/n: 210483465700039 BIOS: American Megatrends Inc. Version 0405. Dated: 03/17/2021 CPU: AMD Ryzen Threadripper PRO 3955WX 16-Cores @ 3900 MHz HVM: Enabled IOMMU: Enabled Cache: 1 MB, 8 MB, 64 MB Memory: 128 GiB DDR4 (max. installable capacity 512 GiB) GFK: 4x RTX 2060 EVO and 1x GT 710 use case: A 4 player couch gaming machine like an X-Box The GT 710 GFK combines the 4 images into one via NDI streams. Problem: The top GFK (slot 1) installed on the MB does not want to start since the change from an i9-9900K Error message on the VM Log: pci,host=0000:41:00.0,id=hostdev0,bus=pci.0,addr=0x6: Failed to mmap 0000:41:00.0 BAR 1. Performance may be slow 2021-06-23T16:07:48.918447Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3 XML: <?xml version='1.0' encoding='UTF-8'?> <domain type='kvm'> <name>Game_1</name> <uuid>c6a0f7ea-92a5-9e75-c7f8-f127a7994073</uuid> <metadata> <vmtemplate xmlns="unraid" name="Windows 10" icon="windows.png" os="windows10"/> </metadata> <memory unit='KiB'>24641536</memory> <currentMemory unit='KiB'>24641536</currentMemory> <memoryBacking> <nosharepages/> </memoryBacking> <vcpu placement='static'>6</vcpu> <cputune> <vcpupin vcpu='0' cpuset='0'/> <vcpupin vcpu='1' cpuset='16'/> <vcpupin vcpu='2' cpuset='1'/> <vcpupin vcpu='3' cpuset='17'/> <vcpupin vcpu='4' cpuset='2'/> <vcpupin vcpu='5' cpuset='18'/> </cputune> <os> <type arch='x86_64' machine='pc-i440fx-5.1'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader> <nvram>/etc/libvirt/qemu/nvram/c6a0f7ea-92a5-9e75-c7f8-f127a7994073_VARS-pure-efi.fd</nvram> </os> <features> <acpi/> <apic/> <hyperv> <relaxed state='on'/> <vapic state='on'/> <spinlocks state='on' retries='8191'/> <vendor_id state='on' value='none'/> </hyperv> </features> <cpu mode='host-passthrough' check='none' migratable='on'> <topology sockets='1' dies='1' cores='3' threads='2'/> <cache mode='passthrough'/> <feature policy='require' name='topoext'/> </cpu> <clock offset='localtime'> <timer name='hypervclock' present='yes'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/user/domains/Game_1/vdisk.img'/> <target dev='hdc' bus='virtio'/> <boot order='1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/> </disk> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/user/domains/Game_1/vdisk2.img'/> <target dev='hdd' bus='virtio'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/> </disk> <disk type='file' device='cdrom'> <driver name='qemu' type='raw'/> <source file='/mnt/user/isos/virtio-win-0.1.190-1.iso'/> <target dev='hdb' bus='ide'/> <readonly/> <address type='drive' controller='0' bus='0' target='0' unit='1'/> </disk> <controller type='pci' index='0' model='pci-root'/> <controller type='ide' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/> </controller> <controller type='virtio-serial' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/> </controller> <controller type='usb' index='0' model='ich9-ehci1'> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x7'/> </controller> <controller type='usb' index='0' model='ich9-uhci1'> <master startport='0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0' multifunction='on'/> </controller> <controller type='usb' index='0' model='ich9-uhci2'> <master startport='2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x1'/> </controller> <controller type='usb' index='0' model='ich9-uhci3'> <master startport='4'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x2'/> </controller> <interface type='bridge'> <mac address='52:54:00:15:0a:5f'/> <source bridge='br0'/> <model type='virtio-net'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/> </interface> <serial type='pty'> <target type='isa-serial' port='0'> <model name='isa-serial'/> </target> </serial> <console type='pty'> <target type='serial' port='0'/> </console> <channel type='unix'> <target type='virtio' name='org.qemu.guest_agent.0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='tablet' bus='usb'> <address type='usb' bus='0' port='1'/> </input> <input type='mouse' bus='ps2'/> <input type='keyboard' bus='ps2'/> <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='de-ch'> <listen type='address' address='0.0.0.0'/> </graphics> <video> <model type='qxl' ram='65536' vram='65536' vgamem='16384' heads='1' primary='yes'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/> </video> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x41' slot='0x00' function='0x0'/> </source> <rom file='/mnt/user/isos/vbios/218088.rom'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/> </hostdev> <memballoon model='none'/> </devices> </domain> i Have also atached the Diagnostics and the Syslog (with cleaning it overfilled) therealbeast-diagnostics-20210623-1757.zip 92.34 kB · 1 download syslog 421.9 kB · 1 download Bios 0602 is out. I am running RTX 2080-ti as second GPU on a Win 10 VM, that works fine. Edited July 30, 20215 yr by frodr
August 5, 20215 yr Author Hi, second GPU is never a problem 🙂 i have installed one more as a dummy GPU now it works fine.
