Two issues found as part of 'Fix Common Problems' plugin - diagnostic report attached
I could use some help troubleshooting two errors. Any thoughts on what I should do?
1. "Machine Check Events detected on your server."
2. Marvel Hard Drive Controller Installed (I've ignored this one because I don't appear to be having issues, but am curious about the group's thoughts now that #1 above appears to be new.)
t-800-diagnostics-20210624-1510.zip
Can anyone help me with this? I'd really appreciate the advice as I'm still a beginner with Unraid. Would like to "officially" ignore or fix these errors.
Harmless MCE issued during cpu core initialization that affects certain hard combinations and is safe to ignore.
Also you might want to consider disabling Mover Logging (Settings - Scheduler - Mover) unless you're having issues
THANK YOU! Will do. I appreciate the input.
