July 12, 20215 yr I keep having this weird problem with read errors on a data disk. I have RMA'd one and my second unit same problem, but it preclears fine. I tried a different SATA cable that doesn't seem to have helped. I am not sure if its got something to do with the type of disk i don't operate any other 8TB drives. Extended Smart finished with no errors. its strange. Anyone else know what is happening here, do i just ignore it ? vault-smart-20210712-2307.zip vault-diagnostics-20210712-2307.zip
July 12, 20215 yr Author this makes sense my parity drives are seagate 8TB disks but are always spinning. i am not going crazy.. thanks JorgeB applied the changes to the 3 drives and rebooted. see how it goes. Edited July 12, 20215 yr by Maticks
July 18, 20215 yr Author Weirdly it happened again to me, i did reboot after issueing both the EPC disable and the lowcurrentspinup. The errors happened when the drive spun up again. i did a system reboot, do i need to power the whole system down for it to take effect ?
July 19, 20215 yr Community Expert Don't think so, but ask in that thread, I don't have any of those disks.
