July 16, 20215 yr hi i know that the dynamix Fan control is only a hard drive fan control and has couple bugs i looking for a plugin or create my own plugin dont know how.. but least a script so when the fans are all shut off due to Array is standby no need but when the heat buids up in the case from GPU CPU or Motherboard or NVMEs there isnt an option to spin up the the rear fans.. or all the fan to exple the heat is there a way i can code something dont know unraid plugin coding and since all the dynmaix plugins all go into the same support forum its basiclly impossible to get support per plugin as it can get missed by other replies.. so too hard to ask for features.. be nice if each plugin had its own support page.. for better support but ya i looking for something to spin up the fans at a percent like the dynamix fan low and high range.. but for when NVME, caches,gpu,motherboard,cpu and possibly unassigned drives that maybe in the array is there options out there? Edited July 16, 20215 yr by comet424
July 16, 20215 yr 7 minutes ago, comet424 said: but when the heat buids up in the case from GPU CPU or Motherboard or NVMEs there isnt an option to spin up the the rear fans.. or all the fan to exple the heat Many motherboards (at least consumer grade) will support fan curves on various fans based upon whatever temperature sensors are present in the BIOS. Check out your options available there.
July 16, 20215 yr Author @Squid ya i seen that but least with the X570 Asus Tuf Gaming you can set the Bios temps on a curve.. but when you use the Dynamix Fan Array thats disabled since Motherboard and Array Fans are the same fans so what i saying is well you cant have both i guess so when Array goes to Standby and shuts off all the fans when Motherboard temperature at bottom of the screen says 40C say then i want it to spins up the Array Fans you can only have Bios or you can only have the Array Fans.. you cant run both... so i wanted the Same Plugin that Fan Control is which is missleading the info says System Temperature.. which it isnt its Array and Cache temperature only so i wanted to Copy that Plugin modify it so Option 1 CPU, Option 2 GPU, Option 3 Motherboard, Option 4 Unassigned drives as there is no option to spin up the array fans for Unassigned Drive temperatures when they hit 45C degrees in my 20 bay case.. no option to spin up the array when that drive is spinning and the array is in standby there is no option in BIOS for unassigned drive temperatures so i looking for options but ill re try the BIOS but its just 2 conflicting as if i remember you set to Manual not automatic so you cant use BIOS if you wanna use same fans for the array but ill try tomorrow oh and there is no GPU in motherboard BIOS for temperature... to run the array fans plus there is no option for Fan Spin up on NVMEs, SATA SSDs, as there should be a seperate Fan controller for those when the Array is in Standby mode Edited July 16, 20215 yr by comet424
July 16, 20215 yr 54 minutes ago, comet424 said: well you cant have both i guess You can, but for a given PWM header, you can either let BIOS control it, or override it in the plugin. For instance, on my mobo the CPU fan controller is accessible in the plugin, I can override it, but I let bios manage it and it ramps up and down with usage/temp as you would expect. Perhaps you just need to split out your fans to different headers to get the balance of control you need?
July 16, 20215 yr Author @tjb_altf4 ah well i know i have 6 headers.. 1 is a opt cpu which sucks as you cant turn it off and i got a pump header which doesnt wanna stop but there is a setting for PWM but there is a new BIOS release i might try so to do things i have 3Way splittler from 1 header to 3 array fans.. but i realyl dont like it you bump a wire any of the 3 fans will spin on its own i dont know why this happens and then i have 2 rear fans on there own headers.. and then i got the chipset cooler and the cpu the dashboard i dunno why it reports FAN0 there is not such thing as fan 0 so the dashboard for Fans is incorrect it doesnt match correctly as i disable the cpu and chipset from the enabled in fan controller. but my mobo doesnt have a GPU in the bios to turn on array fans if its over heating.. and there is no option in the dynamix fan control for SSDs, cache, unassigned drives and i also looking for a feature you dont need to spin up all the fans maybe fans 1 3 7 as an example.. but ill update my BIOS tomorrow and see what happens if i can do both as i couldnt and i not sure if that also the problem i have on 3 way splittler if you bump 1 fan it will run while the other 2 are off.. or you bump the middle one willl cause a 2nd fan to run.. but i dont think 3 way splitters work right.. i think u need 1 fan per header they just dont have enough header s but ya really i wanted is a real break down per drive 38-46C For all the Array and Exhaust fans to kick in Excluding Nvme,SATA SSD 48-70C For Cache 1 (NVME) 48-70C For Cache 2 (SATA SSD) 38-46C For Cache 3 (Sata Spinner) 38-46C For Unassigned Drive 1 38-50C Motherboard Only Run 2 Exhaust Fans forget the Array Fans 50-70C CPU Only Run 1 Exhaust Fan and 2 Array Fans and i want to be able for each Drive to choose what Fans to kick in.. so could be 1 Exhaust 1 Array fan or no Array Fans just 2 Exhaust i just like more options broken down more control what fans can be enabled per option so basiclly that Dynamix Fan Control.. thats Only For Array there should be a complete copy for CACHE 1 CACHE 2 CPU MOTHERBOARD Unassigned drives etc but ill try again tommorrow with a bios update Edited July 16, 20215 yr by comet424
July 16, 20215 yr Author is there a way i could copy the dynamix fan plug in and modify it so i have say 6 copies of it and then modify it 1 for motherboard, 1 for each unassigned drive, 1 for nvme, 1 ssd, cpu,gpu, so there is more control so you have that 1-7 pwm fans for each option so motherboard gets 1-7 pwm fans cpu gets 1-7 pwm fans cach1 gets 1-7 pwm fans and so on and each option gets there own unquie control of the fans Edited July 16, 20215 yr by comet424
July 16, 20215 yr Author so i updated bios you cant do what i want there so back looking for a plugin or a script Scenerio 1. Array Off .Mother board temps hit 40C turn on Fan 1 and Fan 4 Array Off Motherboard temps hit 45C turn on Fan 1 4 6 and 7.. Scenerio 2 Array Off Cache Drive 3 Sata SSD hits 40 turn on Fan 2 and Fan 4 Array Off Cache Drive 3 Sata SSD hits 50 turn on Fan 2 and Fan 5 i want the same options as Auto Fan Control which is really only Array Fan Control but i want a duplicate copy for every Cache Drive individually 1 For Motherboard temp 1 For GPU Temp 1 for CPU TEmp every Unassigned Drive Individually there is not point spinning the Entire 7 Fans if you only need 1 of the 3 Array Fans and 1 or 2 Exhaust Fans so id like more control
June 17, 20224 yr On 7/16/2021 at 11:32 PM, comet424 said: so i updated bios you cant do what i want there so back looking for a plugin or a script Scenerio 1. Array Off .Mother board temps hit 40C turn on Fan 1 and Fan 4 Array Off Motherboard temps hit 45C turn on Fan 1 4 6 and 7.. Scenerio 2 Array Off Cache Drive 3 Sata SSD hits 40 turn on Fan 2 and Fan 4 Array Off Cache Drive 3 Sata SSD hits 50 turn on Fan 2 and Fan 5 i want the same options as Auto Fan Control which is really only Array Fan Control but i want a duplicate copy for every Cache Drive individually 1 For Motherboard temp 1 For GPU Temp 1 for CPU TEmp every Unassigned Drive Individually there is not point spinning the Entire 7 Fans if you only need 1 of the 3 Array Fans and 1 or 2 Exhaust Fans so id like more control So how did you get on with this? Any joy??
