July 20, 20215 yr Unraid keeps giving me a red warning that Disk 6 has read errors ---- 4, to be precise. Jul 5 01:38:32 UNRAID kernel: md: disk6 read error, sector=1952415512 Jul 5 01:38:32 UNRAID kernel: md: disk6 read error, sector=1952415520 Jul 5 01:38:32 UNRAID kernel: md: disk6 read error, sector=1952415528 Jul 5 01:38:32 UNRAID kernel: md: disk6 read error, sector=1952415536 Regularly scheduled parity checks end ok, no issues there. No other known issues with data on the drive and all SMART tests succeed. Is this warning to be believed? Going back to see other read error threads there's been a lot of talk of the multi zone error rates and things of that nature when suggesting to replace disks, well here's Disk 6's stats: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 270 3 Spin_Up_Time POS--K 187 184 021 - 5650 4 Start_Stop_Count -O--CK 100 100 000 - 59 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 100 253 000 - 0 9 Power_On_Hours -O--CK 053 053 000 - 34890 10 Spin_Retry_Count -O--CK 100 253 000 - 0 11 Calibration_Retry_Count -O--CK 100 253 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 56 192 Power-Off_Retract_Count -O--CK 200 200 000 - 36 193 Load_Cycle_Count -O--CK 196 196 000 - 14032 194 Temperature_Celsius -O---K 122 103 000 - 28 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 100 253 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 47 In comparison here is Disk 7's stats which would appear to be a more likely candidate for replacement, yet prompt no issues. ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 12655 3 Spin_Up_Time POS--K 198 182 021 - 7083 4 Start_Stop_Count -O--CK 094 094 000 - 6057 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 199 199 000 - 71 9 Power_On_Hours -O--CK 046 046 000 - 39522 10 Spin_Retry_Count -O--CK 100 100 000 - 0 11 Calibration_Retry_Count -O--CK 100 100 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 116 192 Power-Off_Retract_Count -O--CK 200 200 000 - 56 193 Load_Cycle_Count -O--CK 165 165 000 - 105243 194 Temperature_Celsius -O---K 122 107 000 - 30 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 200 200 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 191 191 000 - 3398 Should disk6 in fact be replaced or is 4 sectors not enough of an issue to worry about and Unraid is just being super sensitive? I'm certainly sure that over the years I've ran drives for a multitude of years with read errors and such and never knew about them and the computer just blissfully kept on chugging along with no problem. Thanks for the info.
July 20, 20215 yr 2 hours ago, Energen said: Should disk6 in fact be replaced or is 4 sectors not enough of an issue to worry about and Unraid is just being super sensitive? You should probably run an extended SMART test on the suspect drives to have better information. And you can share your diagnostics once the tests are done if you need help deciding.
