Help... array not starting... drives stuck on "mounting"
Got home today... server wasn't accessible. I restarted it.
Now it boots, SSH starts... (custom)
but the array won't come all the way up. Disks are stuck in "Mounting"...
What should I do?
parity	WDC_WD5000AAJS-2_WD-WCAS81999021	35°C	488,386,552	-	17,780	13,777	0
disk1	WDC_WD5000AAKS-0_WD-WCAPW4206701	36°C	488,386,552	Mounting	8,947	2,448	0
disk2	WDC_WD5000AAKB-00YSA0_WD-WCAS88027012	34°C	488,386,552	Mounting	6,871	2,335	0
disk3	WDC_WD5000AAKB-00YSA0_WD-WCAS88046177	35°C	488,386,552	25,627,580	4,284	53	0
disk4	WDC_WD5000AAKB-00YSA0_WD-WCAS88046454	34°C	488,386,552	Mounting	8,843	4,672	0
disk5	ST3500320AS_9QM3V3C2	35°C	488,386,552	119,712,416	8,276	579	0
disk6	WDC_WD3000JB-00KFA0_WD-WMAMR1301092	32°C	293,036,152	Mounting	7,966	3,802	0
cache	SAMSUNG_HD080HJ_P_S0DEJ10A133453	42°C	78,124,968	73,190,012	3,092	5,595	0
It finally started.... Took a LONG time though... Anything I should check? just to be safe?
It probably took so long because of the unclean shutdown.  When it came back up it was replaying all the journaled transactions.
