September 16, 20215 yr hi , there i have some problem with Ethernet passthrough UNRAID ver.:6.9.2 motherboard: ASUS TUF GAMING B550M-PLUS (WI-FI) CPU: Ryzen 5800x also i have added another Realtek 2.5G Ethernet on pcie*1 when i want to blind,the device can't be selected also because it is same device, theres' device id are same how should i blind one of them wish you can help me work out it thank yoou Edited September 16, 20215 yr by xenoblade
September 16, 20215 yr You need to use acs override to split the iommu group. Once the ethernet is in its iommu group you can pass it through. It doesn't matter device/vendor id for pci(e) passthrough, you are using source domain:bus:slot.function. Edited September 16, 20215 yr by ghost82
September 17, 20215 yr Author 8 hours ago, ghost82 said: You need to use acs override to split the iommu group. Once the ethernet is in its iommu group you can pass it through. It doesn't matter device/vendor id for pci(e) passthrough, you are using source domain:bus:slot.function. thank you, really help me a lot
