Please help! XFS (sdh1): Corruption warning: Metadata has LSN (202378512:235933456) ahead of current LSN (1:32). Please unmount and run xfs_repair (>= v4.3) to resolve.
21st September - I had some problems with a VM (i didn't check the power/sleep settings) running on a separate SSD (sdh1).  I purchased a new SSD, shutdown the server and installed the new drive, powered the server on, new SSD now named (sdh) Dev1 in the webui.  I didn't notice the error until today.  I checked the diagnostics and the Metadata error is prior to the SSD swap but continues to repeat the error in the logs.
is there any way of clearing this error log?
Thank you!
Edited by Jono W
Solution is in the title:
Check filesystem on that device.
Thank you.
I tried the xfs repair and I get this "fatal error -- File system metadata writeout failed, err=117.  Re-run xfs_repair"
Since you didn't post them, and since you didn't mention it, we don't know what version of Unraid you have. If you don't have a recent version of Unraid you may not have a recent version of xfs_repair.
Please post the xfs_repair command you used and the complete output.
So iI performed the "xfs_repair -n /dev/sdh1"
result: -
root@Tower:~# xfs_repair -n /dev/sdh1
Phase 1 - find and verify superblock...
Phase 2 - using internal log
        - zero log...
        - scan filesystem freespace and inode maps...
sb_icount 64, counted 32
sb_ifree 61, counted 29
sb_fdblocks 61019537, counted 61019541
        - found root inode chunk
Phase 3 - for each AG...
        - scan (but don't clear) agi unlinked lists...
        - process known inodes and perform inode discovery...
        - agno = 0
        - agno = 1
        - agno = 2
        - agno = 3
        - process newly discovered inodes...
Phase 4 - check for duplicate blocks...
        - setting up duplicate extent list...
        - check for inodes claiming duplicate blocks...
        - agno = 0
        - agno = 2
        - agno = 3
        - agno = 1
No modify flag set, skipping phase 5
Phase 6 - check inode connectivity...
        - traversing filesystem ...
        - traversal finished ...
        - moving disconnected inodes to lost+found ...
Phase 7 - verify link counts...
No modify flag set, skipping filesystem flush and exiting.
#######    Then   ##############################################
xfs_repair /dev/sdh1
        - zero log...
Metadata CRC error detected at 0x439496, xfs_agf block 0x8/0x1000
agf has bad CRC for ag 0
Metadata CRC error detected at 0x4643f6, xfs_agi block 0x10/0x1000
agi has bad CRC for ag 0
bad magic # 0x6623c00f for agf 0
bad version # -2051342234 for agf 0
bad sequence # -2114235325 for agf 0
bad length 1346441093 for agf 0, should be 15262348
flfirst 260377600 in agf 0 too large (max = 1014)
fllast 1734774099 in agf 0 too large (max = 1014)
bad uuid 4a286681-f900-0008-000f-830c0067668b for agf 0
bad magic # 0x46494c45 for agi 0
bad version # 805307136 for agi 0
bad sequence # -233627648 for agi 0
bad length # 0 for agi 0, should be 15262348
bad uuid 00000400-0000-0000-0000-040000000000 for agi 0
reset bad agf for ag 0
reset bad agi for ag 0
Metadata CRC error detected at 0x439034, xfs_agfl block 0x18/0x1000
agfl has bad CRC for ag 0
bad agbno 301994752 in agfl, agno 0
freeblk count 1 != flcount 275211915 in ag 0
bad agbno 2952823289 for btbno root, agno 0
bad agbno 33623938 for btbcnt root, agno 0
Metadata CRC error detected at 0x46e02d, xfs_refcountbt block 0x3319e48/0x1000
btree block 0/6697929 is suspect, error -74
bad magic # 0 in refcount btree block 0/6697929
bad refcountbt block count 0, saw 3222242307
agf_freeblks 183182736, counted 0 in ag 0
agf_longest 1734774099, counted 0 in ag 0
agf_btreeblks 275211915, counted 0 in ag 0
bad agbno 939524352 for inobt root, agno 0
bad agbno 2952790016 for finobt root, agno 0
agi_count 16777472, counted 0 in ag 0
agi_freecount 262144, counted 0 in ag 0
agi_freecount 262144, counted 0 in ag 0 finobt
agi unlinked bucket 0 is 117440512 in ag 0 (inode=117440512)
agi unlinked bucket 1 is 0 in ag 0 (inode=0)
agi unlinked bucket 2 is 33554432 in ag 0 (inode=33554432)
agi unlinked bucket 3 is 0 in ag 0 (inode=0)
agi unlinked bucket 4 is 268435456 in ag 0 (inode=268435456)
agi unlinked bucket 5 is 1610612736 in ag 0 (inode=1610612736)
agi unlinked bucket 6 is 6144 in ag 0 (inode=6144)
agi unlinked bucket 7 is 0 in ag 0 (inode=0)
agi unlinked bucket 8 is 1207959552 in ag 0 (inode=1207959552)
agi unlinked bucket 9 is 402653184 in ag 0 (inode=402653184)
agi unlinked bucket 10 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 11 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 12 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 13 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 14 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 15 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 16 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 17 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 18 is 100663296 in ag 0 (inode=100663296)
agi unlinked bucket 19 is 0 in ag 0 (inode=0)
agi unlinked bucket 20 is 0 in ag 0 (inode=0)
agi unlinked bucket 21 is 0 in ag 0 (inode=0)
agi unlinked bucket 22 is 0 in ag 0 (inode=0)
agi unlinked bucket 23 is 65536 in ag 0 (inode=65536)
agi unlinked bucket 24 is 0 in ag 0 (inode=0)
agi unlinked bucket 25 is 0 in ag 0 (inode=0)
agi unlinked bucket 26 is 0 in ag 0 (inode=0)
agi unlinked bucket 27 is 0 in ag 0 (inode=0)
agi unlinked bucket 28 is 805306368 in ag 0 (inode=805306368)
agi unlinked bucket 29 is 1744830464 in ag 0 (inode=1744830464)
agi unlinked bucket 30 is 6144 in ag 0 (inode=6144)
agi unlinked bucket 31 is 768 in ag 0 (inode=768)
agi unlinked bucket 32 is 1241513984 in ag 0 (inode=1241513984)
agi unlinked bucket 33 is 402653440 in ag 0 (inode=402653440)
agi unlinked bucket 34 is 83886080 in ag 0 (inode=83886080)
agi unlinked bucket 35 is 1280 in ag 0 (inode=1280)
agi unlinked bucket 36 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 37 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 38 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 39 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 40 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 41 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 42 is 552670106 in ag 0 (inode=552670106)
agi unlinked bucket 43 is 2746341121 in ag 0 (inode=2746341121)
agi unlinked bucket 44 is 4194304 in ag 0 (inode=4194304)
agi unlinked bucket 45 is 0 in ag 0 (inode=0)
agi unlinked bucket 46 is 4194304 in ag 0 (inode=4194304)
agi unlinked bucket 47 is 0 in ag 0 (inode=0)
agi unlinked bucket 48 is 100663296 in ag 0 (inode=100663296)
agi unlinked bucket 49 is 0 in ag 0 (inode=0)
agi unlinked bucket 50 is 67314688 in ag 0 (inode=67314688)
agi unlinked bucket 51 is 1291863552 in ag 0 (inode=1291863552)
agi unlinked bucket 52 is 1409286144 in ag 0 (inode=1409286144)
agi unlinked bucket 53 is 0 in ag 0 (inode=0)
agi unlinked bucket 54 is 2147483648 in ag 0 (inode=2147483648)
agi unlinked bucket 55 is 1207959552 in ag 0 (inode=1207959552)
agi unlinked bucket 56 is 16793600 in ag 0 (inode=16793600)
agi unlinked bucket 57 is 1536 in ag 0 (inode=1536)
agi unlinked bucket 58 is 0 in ag 0 (inode=0)
agi unlinked bucket 59 is 0 in ag 0 (inode=0)
agi unlinked bucket 60 is 1056964608 in ag 0 (inode=1056964608)
agi unlinked bucket 61 is 0 in ag 0 (inode=0)
agi unlinked bucket 62 is 1073741824 in ag 0 (inode=1073741824)
agi unlinked bucket 63 is 0 in ag 0 (inode=0)
sb_icount 64, counted 0
sb_ifree 61, counted 0
sb_fdblocks 61019537, counted 45757207
root inode chunk not found
        - scan and clear agi unlinked lists...
        - agno = 0
Metadata corruption detected at 0x435c43, xfs_inode block 0x80/0x4000
Metadata corruption detected at 0x435c43, xfs_inode block 0xa0/0x4000
bad CRC for inode 128
bad magic number 0x68 on inode 128
bad version number 0x2 on inode 128
bad next_unlinked 0x30683168 on inode 128
inode identifier 5505735654847827816 mismatch on inode 128
bad CRC for inode 129
bad magic number 0x69 on inode 129
bad version number 0x2 on inode 129
bad next_unlinked 0x30693169 on inode 129
inode identifier 5506017134119571305 mismatch on inode 129
bad CRC for inode 130
bad magic number 0x6a on inode 130
bad version number 0x2 on inode 130
bad next_unlinked 0x306a316a on inode 130
inode identifier 5506298613391314794 mismatch on inode 130
bad CRC for inode 131
bad magic number 0x6b on inode 131
bad version number 0x2 on inode 131
bad next_unlinked 0x306b316b on inode 131
inode identifier 5506580092663058283 mismatch on inode 131
bad CRC for inode 132
bad magic number 0x6c on inode 132
bad version number 0x2 on inode 132
bad next_unlinked 0x306c316c on inode 132
inode identifier 5506861571934801772 mismatch on inode 132
bad CRC for inode 133
bad magic number 0x6d on inode 133
bad version number 0x2 on inode 133
bad next_unlinked 0x306d316d on inode 133
inode identifier 5507143051206545261 mismatch on inode 133
bad CRC for inode 134
bad magic number 0x6e on inode 134
bad version number 0x2 on inode 134
bad next_unlinked 0x306e316e on inode 134
inode identifier 5507424530478288750 mismatch on inode 134
bad CRC for inode 135
bad magic number 0x6f on inode 135
bad version number 0x2 on inode 135
bad next_unlinked 0x306f316f on inode 135
inode identifier 5507706009750032239 mismatch on inode 135
bad CRC for inode 136
bad magic number 0x70 on inode 136
bad version number 0x2 on inode 136
bad next_unlinked 0x30703170 on inode 136
inode identifier 5507987489021775728 mismatch on inode 136
bad CRC for inode 137
bad magic number 0x71 on inode 137
bad version number 0x2 on inode 137
bad next_unlinked 0x30713171 on inode 137
inode identifier 5508268968293519217 mismatch on inode 137
bad CRC for inode 138
bad magic number 0x72 on inode 138
bad version number 0x2 on inode 138
bad next_unlinked 0x30723172 on inode 138
inode identifier 5508550447565262706 mismatch on inode 138
bad CRC for inode 139
bad magic number 0x73 on inode 139
bad version number 0x2 on inode 139
bad next_unlinked 0x30733173 on inode 139
inode identifier 5508831926837006195 mismatch on inode 139
bad CRC for inode 140
bad magic number 0x74 on inode 140
bad version number 0x2 on inode 140
bad next_unlinked 0x30743174 on inode 140
inode identifier 5509113406108749684 mismatch on inode 140
bad CRC for inode 141
bad magic number 0x75 on inode 141
bad version number 0x2 on inode 141
bad next_unlinked 0x30753175 on inode 141
inode identifier 5509394885380493173 mismatch on inode 141
bad CRC for inode 142
bad magic number 0x76 on inode 142
bad version number 0x2 on inode 142
bad next_unlinked 0x30763176 on inode 142
inode identifier 5509676364652236662 mismatch on inode 142
bad CRC for inode 143
bad magic number 0x77 on inode 143
bad version number 0x2 on inode 143
bad next_unlinked 0x30773177 on inode 143
inode identifier 5509957843923980151 mismatch on inode 143
bad CRC for inode 144
bad magic number 0x78 on inode 144
bad version number 0x2 on inode 144
bad next_unlinked 0x30783178 on inode 144
inode identifier 5510239323195723640 mismatch on inode 144
bad CRC for inode 145
bad magic number 0x79 on inode 145
bad version number 0x2 on inode 145
bad next_unlinked 0x30793179 on inode 145
inode identifier 5510520802467467129 mismatch on inode 145
bad CRC for inode 146
bad magic number 0x7a on inode 146
bad version number 0x2 on inode 146
bad next_unlinked 0x307a317a on inode 146
inode identifier 5510802281739210618 mismatch on inode 146
bad CRC for inode 147
bad magic number 0x7b on inode 147
bad version number 0x2 on inode 147
bad next_unlinked 0x307b317b on inode 147
inode identifier 5511083761010954107 mismatch on inode 147
bad CRC for inode 148
bad magic number 0x7c on inode 148
bad version number 0x2 on inode 148
bad next_unlinked 0x307c317c on inode 148
inode identifier 5511365240282697596 mismatch on inode 148
bad CRC for inode 149
bad magic number 0x7d on inode 149
bad version number 0x2 on inode 149
bad next_unlinked 0x307d317d on inode 149
inode identifier 5511646719554441085 mismatch on inode 149
bad CRC for inode 150
bad magic number 0x7e on inode 150
bad version number 0x2 on inode 150
bad next_unlinked 0x307e317e on inode 150
inode identifier 5511928198826184574 mismatch on inode 150
bad CRC for inode 151
bad magic number 0x7f on inode 151
bad version number 0x2 on inode 151
bad next_unlinked 0x307f317f on inode 151
inode identifier 5512209678097928063 mismatch on inode 151
bad CRC for inode 152
bad magic number 0x80 on inode 152
bad version number 0x2 on inode 152
bad next_unlinked 0x30803180 on inode 152
inode identifier 5512491157369671552 mismatch on inode 152
bad CRC for inode 153
bad magic number 0x81 on inode 153
bad version number 0x2 on inode 153
bad next_unlinked 0x30813181 on inode 153
inode identifier 5512772636641415041 mismatch on inode 153
bad CRC for inode 154
bad magic number 0x82 on inode 154
bad version number 0x2 on inode 154
bad next_unlinked 0x30823182 on inode 154
inode identifier 5513054115913158530 mismatch on inode 154
bad CRC for inode 155
bad magic number 0x83 on inode 155
bad version number 0x2 on inode 155
bad next_unlinked 0x30833183 on inode 155
inode identifier 5513335595184902019 mismatch on inode 155
bad CRC for inode 156
bad magic number 0x84 on inode 156
bad version number 0x2 on inode 156
bad next_unlinked 0x30843184 on inode 156
inode identifier 5513617074456645508 mismatch on inode 156
bad CRC for inode 157
bad magic number 0x85 on inode 157
bad version number 0x2 on inode 157
bad next_unlinked 0x30853185 on inode 157
inode identifier 5513898553728388997 mismatch on inode 157
bad CRC for inode 158
bad magic number 0x86 on inode 158
bad version number 0x2 on inode 158
bad next_unlinked 0x30863186 on inode 158
inode identifier 5514180033000132486 mismatch on inode 158
bad CRC for inode 159
bad magic number 0x87 on inode 159
bad version number 0x2 on inode 159
bad next_unlinked 0x30873187 on inode 159
inode identifier 5514461512271875975 mismatch on inode 159
bad CRC for inode 160
bad magic number 0x88 on inode 160
bad version number 0x2 on inode 160
bad next_unlinked 0x30883188 on inode 160
inode identifier 5514742991543619464 mismatch on inode 160
bad CRC for inode 161
bad magic number 0x89 on inode 161
bad version number 0x2 on inode 161
bad next_unlinked 0x30893189 on inode 161
inode identifier 5515024470815362953 mismatch on inode 161
bad CRC for inode 162
bad magic number 0x8a on inode 162
bad version number 0x2 on inode 162
bad next_unlinked 0x308a318a on inode 162
inode identifier 5515305950087106442 mismatch on inode 162
bad CRC for inode 163
bad magic number 0x8b on inode 163
bad version number 0x2 on inode 163
bad next_unlinked 0x308b318b on inode 163
inode identifier 5515587429358849931 mismatch on inode 163
bad CRC for inode 164
bad magic number 0x8c on inode 164
bad version number 0x2 on inode 164
bad next_unlinked 0x308c318c on inode 164
inode identifier 5515868908630593420 mismatch on inode 164
bad CRC for inode 165
bad magic number 0x8d on inode 165
bad version number 0x2 on inode 165
bad next_unlinked 0x308d318d on inode 165
inode identifier 5516150387902336909 mismatch on inode 165
bad CRC for inode 166
bad magic number 0x8e on inode 166
bad version number 0x2 on inode 166
bad next_unlinked 0x308e318e on inode 166
inode identifier 5516431867174080398 mismatch on inode 166
bad CRC for inode 167
bad magic number 0x8f on inode 167
bad version number 0x2 on inode 167
bad next_unlinked 0x308f318f on inode 167
inode identifier 5516713346445823887 mismatch on inode 167
bad CRC for inode 168
bad magic number 0x90 on inode 168
bad version number 0x2 on inode 168
bad next_unlinked 0x30903190 on inode 168
inode identifier 5516994825717567376 mismatch on inode 168
bad CRC for inode 169
bad magic number 0x91 on inode 169
bad version number 0x2 on inode 169
bad next_unlinked 0x30913191 on inode 169
inode identifier 5517276304989310865 mismatch on inode 169
bad CRC for inode 170
bad magic number 0x92 on inode 170
bad version number 0x2 on inode 170
bad next_unlinked 0x30923192 on inode 170
inode identifier 5517557784261054354 mismatch on inode 170
bad CRC for inode 171
bad magic number 0x93 on inode 171
bad version number 0x2 on inode 171
bad next_unlinked 0x30933193 on inode 171
inode identifier 5517839263532797843 mismatch on inode 171
bad CRC for inode 172
bad magic number 0x94 on inode 172
bad version number 0x2 on inode 172
bad next_unlinked 0x30943194 on inode 172
inode identifier 5518120742804541332 mismatch on inode 172
bad CRC for inode 173
bad magic number 0x95 on inode 173
bad version number 0x2 on inode 173
bad next_unlinked 0x30953195 on inode 173
inode identifier 5518402222076284821 mismatch on inode 173
bad CRC for inode 174
bad magic number 0x96 on inode 174
bad version number 0x2 on inode 174
bad next_unlinked 0x30963196 on inode 174
inode identifier 5518683701348028310 mismatch on inode 174
bad CRC for inode 175
bad magic number 0x97 on inode 175
bad version number 0x2 on inode 175
bad next_unlinked 0x30973197 on inode 175
inode identifier 5518965180619771799 mismatch on inode 175
bad CRC for inode 176
bad magic number 0x98 on inode 176
bad version number 0x2 on inode 176
bad next_unlinked 0x30983198 on inode 176
inode identifier 5519246659891515288 mismatch on inode 176
bad CRC for inode 177
bad magic number 0x99 on inode 177
bad version number 0x2 on inode 177
bad next_unlinked 0x30993199 on inode 177
inode identifier 5519528139163258777 mismatch on inode 177
bad CRC for inode 178
bad magic number 0x9a on inode 178
bad version number 0x2 on inode 178
bad next_unlinked 0x309a319a on inode 178
inode identifier 5519809618435002266 mismatch on inode 178
bad CRC for inode 179
bad magic number 0x9b on inode 179
bad version number 0x2 on inode 179
bad next_unlinked 0x309b319b on inode 179
inode identifier 5520091097706745755 mismatch on inode 179
bad CRC for inode 180
bad magic number 0x9c on inode 180
bad version number 0x2 on inode 180
bad next_unlinked 0x309c319c on inode 180
inode identifier 5520372576978489244 mismatch on inode 180
bad CRC for inode 181
bad magic number 0x9d on inode 181
bad version number 0x2 on inode 181
bad next_unlinked 0x309d319d on inode 181
inode identifier 5520654056250232733 mismatch on inode 181
bad CRC for inode 182
bad magic number 0x9e on inode 182
bad version number 0x2 on inode 182
bad next_unlinked 0x309e319e on inode 182
inode identifier 5520935535521976222 mismatch on inode 182
bad CRC for inode 183
bad magic number 0x9f on inode 183
bad version number 0x2 on inode 183
bad next_unlinked 0x309f319f on inode 183
inode identifier 5521217014793719711 mismatch on inode 183
bad CRC for inode 184
bad magic number 0xa0 on inode 184
bad version number 0x2 on inode 184
bad next_unlinked 0x30a031a0 on inode 184
inode identifier 5521498494065463200 mismatch on inode 184
bad CRC for inode 185
bad magic number 0xa1 on inode 185
bad version number 0x2 on inode 185
bad next_unlinked 0x30a131a1 on inode 185
inode identifier 5521779973337206689 mismatch on inode 185
bad CRC for inode 186
bad magic number 0xa2 on inode 186
bad version number 0x2 on inode 186
bad next_unlinked 0x30a231a2 on inode 186
inode identifier 5522061452608950178 mismatch on inode 186
bad CRC for inode 187
bad magic number 0xa3 on inode 187
bad version number 0x2 on inode 187
bad next_unlinked 0x30a331a3 on inode 187
inode identifier 5522342931880693667 mismatch on inode 187
bad CRC for inode 188
bad magic number 0xa4 on inode 188
bad version number 0x2 on inode 188
bad next_unlinked 0x30a431a4 on inode 188
inode identifier 5522624411152437156 mismatch on inode 188
bad CRC for inode 189
bad magic number 0xa5 on inode 189
bad version number 0x2 on inode 189
bad next_unlinked 0x30a531a5 on inode 189
inode identifier 5522905890424180645 mismatch on inode 189
bad CRC for inode 190
bad magic number 0xa6 on inode 190
bad version number 0x2 on inode 190
bad next_unlinked 0x30a631a6 on inode 190
inode identifier 5523186270184296102 mismatch on inode 190
bad CRC for inode 191
bad magic number 0xa7 on inode 191
bad version number 0x2 on inode 191
bad next_unlinked 0x30a731a7 on inode 191
inode identifier 5523467749456039591 mismatch on inode 191
bad CRC for inode 128, will rewrite
bad magic number 0x68 on inode 128, resetting magic number
bad version number 0x2 on inode 128, resetting version number
bad next_unlinked 0x30683168 on inode 128, resetting next_unlinked
cleared root inode 128
bad CRC for inode 129, will rewrite
bad magic number 0x69 on inode 129, resetting magic number
bad version number 0x2 on inode 129, resetting version number
bad next_unlinked 0x30693169 on inode 129, resetting next_unlinked
cleared realtime bitmap inode 129
bad CRC for inode 130, will rewrite
bad magic number 0x6a on inode 130, resetting magic number
bad version number 0x2 on inode 130, resetting version number
bad next_unlinked 0x306a316a on inode 130, resetting next_unlinked
cleared realtime summary inode 130
bad CRC for inode 131, will rewrite
bad magic number 0x6b on inode 131, resetting magic number
bad version number 0x2 on inode 131, resetting version number
bad next_unlinked 0x306b316b on inode 131, resetting next_unlinked
cleared inode 131
bad CRC for inode 132, will rewrite
bad magic number 0x6c on inode 132, resetting magic number
bad version number 0x2 on inode 132, resetting version number
bad next_unlinked 0x306c316c on inode 132, resetting next_unlinked
cleared inode 132
bad CRC for inode 133, will rewrite
bad magic number 0x6d on inode 133, resetting magic number
bad version number 0x2 on inode 133, resetting version number
bad next_unlinked 0x306d316d on inode 133, resetting next_unlinked
cleared inode 133
bad CRC for inode 134, will rewrite
bad magic number 0x6e on inode 134, resetting magic number
bad version number 0x2 on inode 134, resetting version number
bad next_unlinked 0x306e316e on inode 134, resetting next_unlinked
cleared inode 134
bad CRC for inode 135, will rewrite
bad magic number 0x6f on inode 135, resetting magic number
bad version number 0x2 on inode 135, resetting version number
bad next_unlinked 0x306f316f on inode 135, resetting next_unlinked
cleared inode 135
bad CRC for inode 136, will rewrite
bad magic number 0x70 on inode 136, resetting magic number
bad version number 0x2 on inode 136, resetting version number
bad next_unlinked 0x30703170 on inode 136, resetting next_unlinked
cleared inode 136
bad CRC for inode 137, will rewrite
bad magic number 0x71 on inode 137, resetting magic number
bad version number 0x2 on inode 137, resetting version number
bad next_unlinked 0x30713171 on inode 137, resetting next_unlinked
cleared inode 137
bad CRC for inode 138, will rewrite
bad magic number 0x72 on inode 138, resetting magic number
bad version number 0x2 on inode 138, resetting version number
bad next_unlinked 0x30723172 on inode 138, resetting next_unlinked
cleared inode 138
bad CRC for inode 139, will rewrite
bad magic number 0x73 on inode 139, resetting magic number
bad version number 0x2 on inode 139, resetting version number
bad next_unlinked 0x30733173 on inode 139, resetting next_unlinked
cleared inode 139
bad CRC for inode 140, will rewrite
bad magic number 0x74 on inode 140, resetting magic number
bad version number 0x2 on inode 140, resetting version number
bad next_unlinked 0x30743174 on inode 140, resetting next_unlinked
cleared inode 140
bad CRC for inode 141, will rewrite
bad magic number 0x75 on inode 141, resetting magic number
bad version number 0x2 on inode 141, resetting version number
bad next_unlinked 0x30753175 on inode 141, resetting next_unlinked
cleared inode 141
bad CRC for inode 142, will rewrite
bad magic number 0x76 on inode 142, resetting magic number
bad version number 0x2 on inode 142, resetting version number
bad next_unlinked 0x30763176 on inode 142, resetting next_unlinked
cleared inode 142
bad CRC for inode 143, will rewrite
bad magic number 0x77 on inode 143, resetting magic number
bad version number 0x2 on inode 143, resetting version number
bad next_unlinked 0x30773177 on inode 143, resetting next_unlinked
cleared inode 143
bad CRC for inode 144, will rewrite
bad magic number 0x78 on inode 144, resetting magic number
bad version number 0x2 on inode 144, resetting version number
bad next_unlinked 0x30783178 on inode 144, resetting next_unlinked
cleared inode 144
bad CRC for inode 145, will rewrite
bad magic number 0x79 on inode 145, resetting magic number
bad version number 0x2 on inode 145, resetting version number
bad next_unlinked 0x30793179 on inode 145, resetting next_unlinked
cleared inode 145
bad CRC for inode 146, will rewrite
bad magic number 0x7a on inode 146, resetting magic number
bad version number 0x2 on inode 146, resetting version number
bad next_unlinked 0x307a317a on inode 146, resetting next_unlinked
cleared inode 146
bad CRC for inode 147, will rewrite
bad magic number 0x7b on inode 147, resetting magic number
bad version number 0x2 on inode 147, resetting version number
bad next_unlinked 0x307b317b on inode 147, resetting next_unlinked
cleared inode 147
bad CRC for inode 148, will rewrite
bad magic number 0x7c on inode 148, resetting magic number
bad version number 0x2 on inode 148, resetting version number
bad next_unlinked 0x307c317c on inode 148, resetting next_unlinked
cleared inode 148
bad CRC for inode 149, will rewrite
bad magic number 0x7d on inode 149, resetting magic number
bad version number 0x2 on inode 149, resetting version number
bad next_unlinked 0x307d317d on inode 149, resetting next_unlinked
cleared inode 149
bad CRC for inode 150, will rewrite
bad magic number 0x7e on inode 150, resetting magic number
bad version number 0x2 on inode 150, resetting version number
bad next_unlinked 0x307e317e on inode 150, resetting next_unlinked
cleared inode 150
bad CRC for inode 151, will rewrite
bad magic number 0x7f on inode 151, resetting magic number
bad version number 0x2 on inode 151, resetting version number
bad next_unlinked 0x307f317f on inode 151, resetting next_unlinked
cleared inode 151
bad CRC for inode 152, will rewrite
bad magic number 0x80 on inode 152, resetting magic number
bad version number 0x2 on inode 152, resetting version number
bad next_unlinked 0x30803180 on inode 152, resetting next_unlinked
cleared inode 152
bad CRC for inode 153, will rewrite
bad magic number 0x81 on inode 153, resetting magic number
bad version number 0x2 on inode 153, resetting version number
bad next_unlinked 0x30813181 on inode 153, resetting next_unlinked
cleared inode 153
bad CRC for inode 154, will rewrite
bad magic number 0x82 on inode 154, resetting magic number
bad version number 0x2 on inode 154, resetting version number
bad next_unlinked 0x30823182 on inode 154, resetting next_unlinked
cleared inode 154
bad CRC for inode 155, will rewrite
bad magic number 0x83 on inode 155, resetting magic number
bad version number 0x2 on inode 155, resetting version number
bad next_unlinked 0x30833183 on inode 155, resetting next_unlinked
cleared inode 155
bad CRC for inode 156, will rewrite
bad magic number 0x84 on inode 156, resetting magic number
bad version number 0x2 on inode 156, resetting version number
bad next_unlinked 0x30843184 on inode 156, resetting next_unlinked
cleared inode 156
bad CRC for inode 157, will rewrite
bad magic number 0x85 on inode 157, resetting magic number
bad version number 0x2 on inode 157, resetting version number
bad next_unlinked 0x30853185 on inode 157, resetting next_unlinked
cleared inode 157
bad CRC for inode 158, will rewrite
bad magic number 0x86 on inode 158, resetting magic number
bad version number 0x2 on inode 158, resetting version number
bad next_unlinked 0x30863186 on inode 158, resetting next_unlinked
cleared inode 158
bad CRC for inode 159, will rewrite
bad magic number 0x87 on inode 159, resetting magic number
bad version number 0x2 on inode 159, resetting version number
bad next_unlinked 0x30873187 on inode 159, resetting next_unlinked
cleared inode 159
imap claims inode 160 is present, but inode cluster is sparse, correcting imap
imap claims inode 161 is present, but inode cluster is sparse, correcting imap
imap claims inode 162 is present, but inode cluster is sparse, correcting imap
imap claims inode 163 is present, but inode cluster is sparse, correcting imap
imap claims inode 164 is present, but inode cluster is sparse, correcting imap
imap claims inode 165 is present, but inode cluster is sparse, correcting imap
imap claims inode 166 is present, but inode cluster is sparse, correcting imap
imap claims inode 167 is present, but inode cluster is sparse, correcting imap
imap claims inode 168 is present, but inode cluster is sparse, correcting imap
imap claims inode 169 is present, but inode cluster is sparse, correcting imap
imap claims inode 170 is present, but inode cluster is sparse, correcting imap
imap claims inode 171 is present, but inode cluster is sparse, correcting imap
imap claims inode 172 is present, but inode cluster is sparse, correcting imap
imap claims inode 173 is present, but inode cluster is sparse, correcting imap
imap claims inode 174 is present, but inode cluster is sparse, correcting imap
imap claims inode 175 is present, but inode cluster is sparse, correcting imap
imap claims inode 176 is present, but inode cluster is sparse, correcting imap
imap claims inode 177 is present, but inode cluster is sparse, correcting imap
imap claims inode 178 is present, but inode cluster is sparse, correcting imap
imap claims inode 179 is present, but inode cluster is sparse, correcting imap
imap claims inode 180 is present, but inode cluster is sparse, correcting imap
imap claims inode 181 is present, but inode cluster is sparse, correcting imap
imap claims inode 182 is present, but inode cluster is sparse, correcting imap
imap claims inode 183 is present, but inode cluster is sparse, correcting imap
imap claims inode 184 is present, but inode cluster is sparse, correcting imap
imap claims inode 185 is present, but inode cluster is sparse, correcting imap
imap claims inode 186 is present, but inode cluster is sparse, correcting imap
imap claims inode 187 is present, but inode cluster is sparse, correcting imap
imap claims inode 188 is present, but inode cluster is sparse, correcting imap
imap claims inode 189 is present, but inode cluster is sparse, correcting imap
imap claims inode 190 is present, but inode cluster is sparse, correcting imap
imap claims inode 191 is present, but inode cluster is sparse, correcting imap
        - agno = 1
        - agno = 2
        - agno = 3
root inode lost
        - agno = 0
        - agno = 2
        - agno = 3
        - agno = 1
Phase 5 - rebuild AG headers and trees...
        - reset superblock...
reinitializing root directory
reinitializing realtime bitmap inode
reinitializing realtime summary inode
        - resetting contents of realtime bitmap and summary inodes
Phase 7 - verify and correct link counts...
SB summary counter sanity check failed
Metadata corruption detected at 0x47518b, xfs_sb block 0x0/0x1000
libxfs_bwrite: write verifier failed on xfs_sb bno 0x0/0x1000
xfs_repair: Releasing dirty buffer to free list!
xfs_repair: Refusing to write a corrupt buffer to the data device!
xfs_repair: Lost a write to the data device!
fatal error -- File system metadata writeout failed, err=117.  Re-run xfs_repair.root@Tower:~#
Thanks 👍
That suggests a xfs_repair issue, update to v6.10-rc1 and try again, it includes newer xfs-progs.
Okay, I will try that, thank you 👍
