September 24, 20215 yr Hello guys! I am currently running my unraid-build(6.9.2) on an older HP Z600 setup. While this is quite old hardware it works really well for my use. I am trying to have some fun with plex/emby and passthrough the graphics card. The first thing I did was download the "Nvidia driver" plugin, followed by the "GPU statistics" plugin. Unfortunately none of these seem to recognise my GPU. I know that Unraid sees the GPU because when i run lspci -v i see it here: 28:00.0 VGA compatible controller: NVIDIA Corporation G94GL [Quadro FX 1800] (rev a1) (prog-if 00 [VGA controller]) Subsystem: NVIDIA Corporation G94GL [Quadro FX 1800] Flags: bus master, fast devsel, latency 0, IRQ 5, IOMMU group 16 Memory at f6000000 (32-bit, non-prefetchable) [size=16M] Memory at e0000000 (64-bit, prefetchable) [size=256M] Memory at f4000000 (64-bit, non-prefetchable) [size=32M] I/O ports at e000 [size=128] Expansion ROM at 000c0000 [virtual] [disabled] [size=128K] Capabilities: [60] Power Management version 3 Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [78] Express Endpoint, MSI 00 Capabilities: [b4] Vendor Specific Information: Len=14 <?> Capabilities: [100] Virtual Channel Capabilities: [128] Power Budgeting <?> Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?> Kernel modules: nvidia_drm, nvidia The Nvidia-driver plugin gives me the following error: NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running. Does anyone know how I can begin to fix this? It might just be possible that my HW is too old...? Thanks in advance!
September 25, 20215 yr Author Bumping myself to the top, hopefully someone has seen this problem before?
December 28, 20214 yr Did you get this resolved? It is happening all of a sudden to me. it was working fine until I think the latest beta.
April 25, 20224 yr On 12/28/2021 at 8:43 PM, mgworek said: Did you get this resolved? It is happening all of a sudden to me. it was working fine until I think the latest beta. Push! I have the same problem.....
