November 16, 20214 yr Hi guys, I am new to Unraid just built my server recently and found out about preclear about 3 days ago. I did have 3 drives already running on the array. So I took them all off and tested them all. All of them are 6tb Exos Seagate. The tests ran for almost a day and a half. Could you please check if all the drives are clear and good to use? There are 6 drives in total. I lost one's data but, I did dload the SMARTS file it and all other ones. So I will be posting both preclear and SMARTS data. For some reason SMARTS Extended self test doesn't work for me it stops at 10%. Thank you hoping to hear from you soon. preclear_disk_WSE0Q0JE_4757.txt preclear_disk_WNB188M3_8997.txt preclear_disk_WNB17R6M_14230.txt preclear_disk_WSE0HLXA_3234.txt preclear_disk_WNB18B8Q_9249.txt ST6000NM021A-2R7101_WSE0Q02Z-20211116-0532.txt ST6000NM021A-2R7101_WNB17R6M-20211115-0105.txt ST6000NM021A-2R7101_WNB188M3-20211115-0105.txt ST6000NM021A-2R7101_WNB18B8Q-20211115-0105.txt ST6000NM021A-2R7101_WSE0HLXA-20211115-0105.txt ST6000NM021A-2R7101_WSE0Q02Z-20211115-0105.txt
November 16, 20214 yr Author Ok after I used preclear all the drives were showing up as unmountable. So I am formatting them again and rebuilding the array. Will update if something goes wrong. Edit: Ok Array got rebuilt that was fast. Going to try copying files back onto them again. Edited November 16, 20214 yr by Roshill
November 16, 20214 yr All fine. 2 hours ago, Roshill said: For some reason SMARTS Extended self test doesn't work for me it stops at 10% Pls disable spindown timer during extended test, it will make the operation abort.
November 16, 20214 yr Author Thank you for the confirmation. I will remember to disable it when I do it next time. Just wanted to be sure as the drives came from really far away.
