December 15, 20214 yr this is the error im getting. i dont know what other info is needed but here is what i have. can someone point me in the right direction? [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-envfile: executing... [cont-init.d] 01-envfile: exited 0. [cont-init.d] 10-adduser: executing... ------------------------------------- _ () | | ___ _ __ | | / __| | | / \ | | \__ \ | | | () | |_| |___/ |_| \__/ Brought to you by linuxserver.io ------------------------------------- To support the app dev(s) visit: Certbot: https://supporters.eff.org/donate/support-work-on-certbot To support LSIO projects visit: https://www.linuxserver.io/donate/ ------------------------------------- GID/UID ------------------------------------- User uid: 99 User gid: 100 ------------------------------------- [cont-init.d] 10-adduser: exited 0. [cont-init.d] 20-config: executing... [cont-init.d] 20-config: exited 0. [cont-init.d] 30-keygen: executing... using keys found in /config/keys [cont-init.d] 30-keygen: exited 0. [cont-init.d] 50-config: executing... Variables set: PUID=99 PGID=100 TZ=America/Los_Angeles URL=reekonunraid.com SUBDOMAINS=wildcard EXTRA_DOMAINS= ONLY_SUBDOMAINS=true VALIDATION=dns CERTPROVIDER= DNSPLUGIN=cloudflare [email protected] STAGING=false Using Let's Encrypt as the cert provider SUBDOMAINS entered, processing Wildcard cert for only the subdomains of reekonunraid.com will be requested E-mail address entered: [email protected] dns validation via cloudflare plugin is selected Different validation parameters entered than what was used before. Revoking and deleting existing certificate, and an updated one will be created Generating new certificate Saving debug log to /var/log/letsencrypt/letsencrypt.log Account registered. Requesting a certificate for *.reekonunraid.com Unsafe permissions on credentials configuration file: /config/dns-conf/cloudflare.ini Error determining zone_id: 6003 Invalid request headers. Please confirm that you have supplied valid Cloudflare API credentials. (Did you copy your entire API token/key? To use Cloudflare tokens, you'll need the python package cloudflare>=2.3.1. This certbot is running cloudflare 2.8.15) Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details. ERROR: Cert does not exist! Please see the validation error above. Make sure you entered correct credentials into the /config/dns-conf/cloudflare.ini file.
