January 2, 20224 yr hi there. I just came across a weird issue with my network speed. I noticed that the file transfer to both of my my Windows machines is capped at around 500 Mbit/s. The weird thing is, the speed does not drop while docker is disabled. With docker disabled I get around 800 Mbits. I tested with iperf after a reboot in all directions, multiple connections also tested. Network speed drops to around 500 Mbits as soon as I start one docker container which is on the br0 network. It does not matter how much dockers on br0 I start. It seems like some kind of limitation kicks in at the moment when br0 gets used. My custom docker network for SWAG does not have that problem. It only happens when I start a docker with dedicated IP on br0. Tried to disable bonding, no effect. Unraid runs on a AsRock H310CM-ITX/ac Board with Intel Core i3-8100, 24GB of RAM, NVIDIA RTX3060 and Intel I219V NIC (onboard). Any ideas what could cause this? Thank you in advance!
May 18, 20233 yr Did you ever find a way around this? i'm finding a very similar issue where all networking is capped to about 500Mbit whenever the docker is running. Even if I put a container on host it's throughput is capped, if I set up a separate bridge on a different NIC it is still capped, if I speedtest on a VM on that bridge it is capped. if I disable docker it runs at line speed, used to be much faster. perhaps IPvlan VS MACvlan? I havent tried comparing that yet.
July 15, 20233 yr Old post but experienced the same. Was debugging slow samba speeds. You can see below at which point the docker service was enabled. Macvlan IPvlan made no difference. Any suggestions? [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 112 MBytes 938 Mbits/sec [ 4] 1.00-2.00 sec 112 MBytes 939 Mbits/sec [ 4] 2.00-3.00 sec 112 MBytes 936 Mbits/sec [ 4] 3.00-4.00 sec 112 MBytes 941 Mbits/sec [ 4] 4.00-5.00 sec 111 MBytes 931 Mbits/sec [ 4] 5.00-6.00 sec 112 MBytes 936 Mbits/sec [ 4] 6.00-7.00 sec 112 MBytes 939 Mbits/sec [ 4] 7.00-8.00 sec 111 MBytes 933 Mbits/sec [ 4] 8.00-9.00 sec 111 MBytes 934 Mbits/sec [ 4] 9.00-10.00 sec 112 MBytes 937 Mbits/sec [ 4] 10.00-11.00 sec 111 MBytes 927 Mbits/sec [ 4] 11.00-12.00 sec 111 MBytes 931 Mbits/sec [ 4] 12.00-13.00 sec 112 MBytes 940 Mbits/sec [ 4] 13.00-14.00 sec 112 MBytes 935 Mbits/sec [ 4] 14.00-15.00 sec 112 MBytes 938 Mbits/sec [ 4] 15.00-16.00 sec 112 MBytes 939 Mbits/sec [ 4] 16.00-17.00 sec 112 MBytes 938 Mbits/sec [ 4] 17.00-18.00 sec 111 MBytes 933 Mbits/sec [ 4] 18.00-19.00 sec 112 MBytes 938 Mbits/sec [ 4] 19.00-20.01 sec 111 MBytes 929 Mbits/sec [ 4] 20.01-21.00 sec 110 MBytes 926 Mbits/sec [ 4] 21.00-22.00 sec 111 MBytes 929 Mbits/sec [ 4] 22.00-23.00 sec 111 MBytes 930 Mbits/sec [ 4] 23.00-24.00 sec 112 MBytes 937 Mbits/sec [ 4] 24.00-25.01 sec 21.2 MBytes 176 Mbits/sec [ 4] 25.01-26.01 sec 59.4 MBytes 498 Mbits/sec [ 4] 26.01-27.01 sec 48.0 MBytes 403 Mbits/sec [ 4] 27.01-28.00 sec 62.6 MBytes 531 Mbits/sec [ 4] 28.00-29.01 sec 31.1 MBytes 259 Mbits/sec [ 4] 29.01-30.00 sec 99.0 MBytes 836 Mbits/sec [ 4] 30.00-31.00 sec 38.1 MBytes 319 Mbits/sec [ 4] 31.00-32.01 sec 48.8 MBytes 404 Mbits/sec [ 4] 32.01-33.00 sec 35.8 MBytes 304 Mbits/sec [ 4] 33.00-34.01 sec 44.2 MBytes 369 Mbits/sec [ 4] 34.01-35.00 sec 95.0 MBytes 802 Mbits/sec [ 4] 35.00-36.00 sec 56.5 MBytes 473 Mbits/sec [ 4] 36.00-37.01 sec 26.5 MBytes 220 Mbits/sec [ 4] 37.01-38.01 sec 37.0 MBytes 311 Mbits/sec [ 4] 38.01-39.01 sec 67.9 MBytes 570 Mbits/sec [ 4] 39.01-40.01 sec 25.5 MBytes 214 Mbits/sec [ 4] 40.01-41.00 sec 55.0 MBytes 464 Mbits/sec [ 4] 41.00-42.00 sec 31.5 MBytes 264 Mbits/sec [ 4] 42.00-43.00 sec 71.5 MBytes 600 Mbits/sec [ 4] 43.00-43.60 sec 27.4 MBytes 380 Mbits/sec
