January 2, 20224 yr My unRAID tower has gotten pretty wonky lately - lots of slow downs and PleX not working well or sometimes not at all. I looked through the error logs and found a few that I do not understand: For example: Jan 2 02:18:52 Tower kernel: Plex Media Scan[17833]: segfault at 14d191b3c030 ip 000014d194cbff80 sp 00007ffedcaf45b0 error 4 in ld-musl-x86_64.so.1[14d194c76000+53000] Jan 2 02:18:52 Tower kernel: Code: 0f b6 49 06 48 c1 e1 08 48 09 c1 41 0f b6 41 07 48 09 c8 eb 02 48 98 48 8b 6c 24 28 45 85 e4 74 3a 41 0f b6 4a ff 48 8d 0c 49 <0f> b6 54 4d 00 c1 e2 18 0f b6 74 4d 01 48 c1 e6 10 48 63 d2 48 09 Also, lots of entries about fan temperature and fan speed - must be related to a plugin in installed. Parity check ran last night - found 400 errors, which is unusual - usually there are zero. My main use is for Plex and Emby. I use NGINX for reverse proxy. I also have SABNZB/RADARR/SONARR set up. I have a few other containers running, but those are the main ones I use. I don't normally run any VMs. I have not upgraded to 6.9.2 yet. I don't want to break my NVIDIA GPU set up (for PleX transcoding), and I remember getting this going on 6.9.1 to be a little painful - maybe it's easier now. Thanks for the help. tower-diagnostics-20220102-1228.zip
January 3, 20224 yr Community Expert Those Plex segfaults appear to be normal, at least I keep seem them in many diags, as for the sync errors, any unclean shutdown?
