Missing Drives after Power Surge
I suffered a power surge on new years day which caused my server (HP DL380 G7) to go offline.
When rebooting the server, the 8 600gb drives in the main enclosure were missing. the 4 2TB drives that are in a separate disk shelf (2 parity 2 data drives) are present but the array is still in a failed state. I rebooted the system (I remembered this happening previously and a reboot solved it) but this has had no apparent effect.
I can see the drives in the iLO console (image below) but they do not appear in unraid or when i run sudo fdisk -l or sudo lshw -class disk
Looking at the syslog, I can't find any reference to the drives, but that might be because I'm unfamiliar with these logs and what I should be looking for. The diagnostics zip are attached
If there is anyway to recover the drives into the system or if there is a hardware failure that can be identified for replacement I would appreciate any guidance.
Thanks
rookery-diagnostics-20220102-1910.zip
