[SOLVED] Problem with LAG
Hi guys looking for some help with setting up Link Aggregation. For some reason when I plug in both cables into my Supermicro board. I loose all connectivity. If I remove one of the ethernet cables it works again.
I set up LAG on my netgear switch for ports 38 and 40.
My unraid network settings are in attachment which I believe is correct as I want a 2Gbe link.
Sent from my SM-G991B using Tapatalk
Edited by bally12345
  • bally12345 changed the title to [SOLVED] Problem with LAG
