Issue with routing dockers through another container
Typically, this works well for me.  However, if the routing container disappears then the web interfaces gets stuck in a loop of trying to rebuild all the dependent containers.  It never returns so that I can fix the underlying problem.
 The underlying issue is that when I updated glueTUN it disappeared and became an abandoned image.  So I need to re-install it.
I had to edit every dependent docker to no longer route through glueTUN, then apply and stop the docker.  I could then add glueTUN back and redo all the other dockers.
Is this how it is expected to work?
