January 26, 20224 yr I need advice on how to properly set up Dynamix WireGuard and a router to make it all work? problem to connect in the network and I can't connect outside the network when I'm running WireGuard I've tried everything and even via ip which is through a tunnel, so I can't connect. Thank you for any advice
