Problems with Permisions after replacing drive
Hi, I had a drive fail (disk5) and replaced it.
Unraid did it's thing and completed this afternoon stating "Parity sync / Data rebuild finished (0 errors)"
My PLEX docker is unable to run properly. Logs show "PMS: failure detected. Read/write access is required for path: /config/Library/Application Support/Plex Media Server".  Same with DiskSpeed. Both won't open the WebGUI.
I attempted to remove/reinstall Diskspeed but the install failed badly and it doesn't even start now.
When I open the Plex user console, the /mnt directory is seen as empty.
I also noticed this with disk5 (the new drive) while looking around trying to figure out what the problem is:
drwxrwxrwx  3 nobody users  48 Mar  2 16:21 disk4/
d?????????  ? ?      ?       ?            ? disk5/
drwxrwxrwx  1 nobody users 244 Mar  2 16:21 user/
Any ideas what caused that or how to fix it? Would this likely be related to the Docker permissions problem?
I'm thinking if I attempt to manually configure permissions on disk5 I could really break something or maybe lose data.
Thanks.
Edited by Darronn
Solved by Darronn
Don't panic.  If you do something just to be doing something, you will probably only complicate the problem.  And Don't reboot until you have done the following!
Please post up your Diagnostics file   (    Tools    >>>    Diagnostics   ) in a new post.  Then one of the Gurus will have some data to determine what your problem is and how to fix it.
Thanks for the reply. I was able to figure it out and fixed it.
I stopped and started the array and disk 5 showed up as unmountable.
Ran xfs_repair and that fixed the disk/permissions issue but the Dockers were still messed up.
Restored appdata from last backup and all is working fine again.
