May 3, 201115 yr Hello All, Been running an unraid system since January 2011 with no issues. I am currently using a system that has six 2 tb drives installed. I now have a spare 2 tb drive that I would like to pre clear so it is tested and ready to insert when a drive fails in the future. The issue I have is that the six installed drives occupy the 6 onboard sata ports. What are my options as far as temporarily installing the spare drive just to preclear it? I am running unraid server 4.6 at the moment. If I have to take the system offline for the duration of the preclear that is not a problem. I am just not sure of the correct procedure to do this so I don't screw up my existing configuration in any way. Any suggestions are welcome. Thanks for your input, Jim Spence
May 3, 201115 yr Stop the array Copy the config folder on the flash drive to a safe place, not on the unRAID array. power down install the drive to be pre-cleared on an available port, temporarily disconnecting one of the array drives disconnect a SECOND array drive as well. This way, unRAID will think there are two drives that have failed and not try to use th new drive as a replacement. With two original array drives disconnected, and the new one to be pre-cleared connected, power up. Because two drives have failed, (are disconnected) it will not start by itself. Clear the new drive using the pre-clear script. You can verify you have the correct drive by its model/serial number before confirming "Yes" to its prompt to continue. after the pre-clear has finished, power down, remove the pre-cleared drive, re-connect the other two and power up. As an alternative, load a spare flash drive with the free version of unRAID, boot ANY other PC with it, install the new drive on it and pre-clear it there. There is no need to have an array assigned. Joe L.
May 3, 201115 yr Author Joe, I really appreciate the quick and detailed response. I will follow your advice. Have a good one. Thanks again, Jim
