Checking what I need to do to reformat my Flash Drive and start again
Evening Fellow Unraid Forum Members,
I've been messing around with my Unraid setup on a "test" PC and have installed a whole bunch of apps, disks, and configurations. I'm now ready to plug it into my "main" server and start migrating data across, and want to reset the unraid installation back to the default fresh install and build it from there. I've backed up the USB data and copied off the ".key" file.
Before I reformat and reset, I just want to confirm that all I need to do after reinstalling the fresh unriad on the same USB is to copy the key file back into the config folder?
Cheers.
Solved by itimpi
This
24 minutes ago, itimpi said:
This
ideal - thank you.
