March 30, 20224 yr Just shutdown, installed replacement (larger) drive, booted up to start the rebuild and got this. Diagnostics attached. Edited March 31, 20224 yr by Squid Private stuff contained in diagnostics from ancient version of the OS
March 31, 20224 yr Everything looks good. Looks like the file it was complaining about is an ancient config file and no longer used ( or you're using it from a user script or something)
April 1, 20224 yr Author I did have a user script for HDD temps many moons ago. Before the Container version of that. So I should be able to clean that up and it won't be a problem?
April 2, 20224 yr Author I took a look at the script and it lines up with the settings in the WebUI, but it’s dated 2009. It’s possible it hasn’t changed since then. I also don’t see any other “stuff” in that file, including user scripts. Is it possible it’s referencing another file and the actual problem is somewhere else?
