April 21, 20224 yr I recently installed an ASUS XG-C100C 10G PCI-E Network Adapter in my server with Supermicro X9DRi-LN4+ with 4x intel integrated NICs (one being used currently) It appears Unraid is recognizing it, but it is not showing up in network settings to do anything with. Is there something Im missing? IOMMU group 15:[1d6a:94c0] 03:00.0 Ethernet controller: Aquantia Corp. Device 94c0 (rev 03) 03:00.0 Ethernet controller: Aquantia Corp. Device 94c0 (rev 03) Subsystem: ASUSTeK Computer Inc. Device 8812 Flags: bus master, fast devsel, latency 0, IRQ 11, NUMA node 0 Memory at df800000 (64-bit, non-prefetchable) [size=512K] Memory at df8a0000 (64-bit, non-prefetchable) [size=4K] Memory at df400000 (64-bit, non-prefetchable) [size=4M] Expansion ROM at df880000 [disabled] [size=128K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+ Capabilities: [70] Express Endpoint, MSI 00 Capabilities: [b0] MSI-X: Enable- Count=32 Masked- Capabilities: [100] Advanced Error Reporting Capabilities: [148] Virtual Channel Capabilities: [168] Device Serial Number 00-00-00-00-00-00-00-00 Capabilities: [178] Secondary PCI Express <?> Capabilities: [198] Physical Layer 16.0 GT/s <?> Capabilities: [1bc] Lane Margining at the Receiver <?> Capabilities: [1d4] Latency Tolerance Reporting Capabilities: [1dc] L1 PM Substates Capabilities: [1ec] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?> Capabilities: [2ec] Data Link Feature <?> Capabilities: [2f8] Precision Time Measurement Capabilities: [304] Vendor Specific Information: ID=0003 Rev=1 Len=054 <?> server-diagnostics-20220420-2016.zip Edited April 21, 20224 yr by Kirsanth
April 21, 20224 yr No driver but you're using a very old Unraid release, try v6.9.2 or latest v6.10-0-rc4
April 21, 20224 yr Author The plan to update is on the horizon, but if Im not mistaken the driver for this card was put in around 6.7ish
April 21, 20224 yr 3 minutes ago, Kirsanth said: but if Im not mistaken the driver for this card was put in around 6.7ish Don't know about that, but no driver is being loaded for that NIC: 03:00.0 Ethernet controller [0200]: Aquantia Corp. Device [1d6a:94c0] (rev 03) Subsystem: ASUSTeK Computer Inc. Device [1043:8812]
April 21, 20224 yr Author Could it be this is some new version of the card where the appropriate driver isnt being installed? Is there anything else that I could troubleshoot to see why this isnt working? There are a bunch of other posts showing that the card is supported. Any help is very much appreciated, Im pretty new to this whole linux world.
