May 19, 20224 yr One of my disks today went to unsuppoted file system. I brought up the array in maintenance mode and did xfs_repair to fix the issue and the drive is back in the array. The issue I have now is all my files are in lost+found folder. Is there a way to recover these files without having to manually copy all the files back to the correct directory? Attaching my Diag file. tower-diagnostics-20220519-1035.zip
May 19, 20224 yr Community Expert 2 minutes ago, Scott Harkless said: The issue I have now is all my files are in lost+found folder. Is there a way to recover these files without having to manually copy all the files back to the correct directory? Unfortunately not. Files get put into the lost+found folder when the repair process was not able to find their directory entry to figure out their name (in which case they are given a random numeric name) or where they belong in the file system. It is often easier to restore from a backup (if you have one) rather than putting in the effort required to sort out the lost+found folder.
May 19, 20224 yr Author Is there a way to make the parity rebuild that drive? I dont have a backup of all the files from that drive. Should I just do an extended smart test on the drive to make sure its not failing or is there a better way to test ?
May 19, 20224 yr Community Expert 1 hour ago, Scott Harkless said: Is there a way to make the parity rebuild that drive? I dont have a backup of all the files from that drive. Should I just do an extended smart test on the drive to make sure its not failing or is there a better way to test ? No, Parity will be reflecting the current contents of the drive (including the lost+found folder). Parity has no knowledge of files - only disk sectors so in that sense it is not content aware. Parity is about protecting you against disk failure - it does not protect you from corruption at the file system level when the dixk has not failed. That is one reason that having parity protection is not a substitute for having backups outside the array.
