MCE Hardware error detected by "Fix Common Problems"
As per title. My system has been stable. Diagnostics are attached. Couldn't find any other posts that are similar based on my understanding. Is the reference to "microcode" in the syslog relevant?
Thanks in advance
tower-diagnostics-20220527-0930.zip
Solved by Squid
May 26 11:01:06 Tower mcelog: failed to prefill DIMM database from DMI data
May 26 11:01:06 Tower mcelog: Kernel does not support page offline interface
More than likely not an issue and safe to ignore, but maybe a BIOS update would solve it
Thanks for the input, it is much appreciated.
